Need help with hoses
Old Jun 7, 2006 | 10:11 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Need help with hoses
The PCV valve is located on the passenger's side rear valve cover if it is a 289. Pic.....
[IMG]local://upfiles/10034/B7B4C3B3A8844BB1A698FB84648F13D1.jpg[/IMG]
[IMG]local://upfiles/10034/CBB2DBDA2B714D81A0D88C69E54B862C.jpg[/IMG]
Old Jun 7, 2006 | 10:14 PM
  #22
P Zero's Avatar
P Zero
I cant remember.... it was so long ago when I got rid of all that stuff....like '93 or something like that. I dont think it had one though.
-P.
Old Jun 7, 2006 | 10:24 PM
  #23
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: P Zero
-P.
It didn't have what? A PCV valve and hose connected to the carb? Of course it does.
Old Jun 8, 2006 | 06:48 PM
  #24
coda618's Avatar
coda618
Hello,
The PCV (Positive Crankcase Ventilation) Hose goes from the rear of the passenger side valve cover to the inlet at the rear base of the carb. You should replace that hose. They are readily available at parts suppliers. I just got a motorcraft for about 11 bucks. You must also have a PCV valve as well in the valve cover gromet. If there is one in there already, pull it and shake. It should not be clogged and the peice inside should rattle around freely. Better yet, Just buy a new one. A FRAM is prob two bucks.
It is not dangerous if missing. However, you should have them in place.
One other thing that I notice in your picture is that the choke tube-the one coming from the exaust manifold to the choke- is not secured. Tighted the brass fitting.
Other than that you should be fine. It appears that the peice removed was some type of heater/water valve. Should not be an issue if it is not there.
Good Luck
Old Jun 8, 2006 | 06:57 PM
  #25
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: coda618
Hello,
Good Luck
I like those down home, tell it like it is replies. Good job Cobra 618.
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
lmurf60
Sep 24, 2015 10:07 PM
Demodulates
Sep 18, 2015 11:14 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
