New Alternator Install
Old Sep 17, 2006 | 08:05 PM
  #21
THUMPIN455's Avatar
THUMPIN455
Default RE: New Alternator Install
The little box is a RELAY.. it is probably powering something else.. Its a really strange place to put it.. Chase the wires and see where it goes.. What its hooked to.. Shouldnt be a relay on the alt wires.. There should be a relay for things like the lights, stereos, electric fans, anything that requires a bunch of amperage draw that a switch cant handle on its own.
Man my typin is goin south fast.. gotta fix everything before I post it.. stuid fat dyslexic fingers.. Im not dyslexic but my fingers apparently are.
Old Sep 17, 2006 | 08:10 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: THUMPIN455
Thanks for clarifying that. The VR is located on the passenger side on all Mustangs from 65-69. Here is a pic of mine. Now, get out your trusty drill and make it happen.
[IMG]local://upfiles/10034/B9BEA52B820A4994A03295524D248270.jpg[/IMG]
Old Sep 17, 2006 | 09:25 PM
  #23
Shifty101Easy's Avatar
Shifty101Easy
ok, so this is an underside view of whatever the little cube thing is....and the two blue wires appear to be grounded onto the the screw that holds the cube to the firewall one comes out of the little cube and straight to the mounting bolt, the other goes to the firewall...one red wire goes to the firewall....the other blue wire to the solenoid from one of the little terminals on the cube....
the next pic is the voltage regulator that i just bought....4 male connectors...4 female wires...i jsut need to know what ones go on what....
[IMG]local://upfiles/12972/89B403F584EF4E32BDB298F6FC121274.jpg[/IMG]
[IMG]local://upfiles/12972/19C13363404842E79A0C1B735BA976E0.jpg[/IMG]
Old Sep 17, 2006 | 10:00 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
Trash that little box and hook it up correctly. How much guidance do you need?
Old Sep 17, 2006 | 10:01 PM
  #25
Shifty101Easy
also, soring, why is yours on the driver side?
Old Sep 17, 2006 | 10:05 PM
  #26
Soaring's Avatar
Soaring
I ♥ Acer
Aha...good observation. I spent about 18 years in Japan and England, so I get my directions confused. You are correct, it is on the driver's side.
Old Sep 17, 2006 | 10:11 PM
  #27
Shifty101Easy
just need to know if it matters where i stick the 4 wires on the 4 prongs on the voltage regulator? can i just put them on any?
Old Sep 17, 2006 | 11:04 PM
  #28
Shifty101Easy
so basically my car didnt even have a voltage regulator??
i have the new one mounted up, i just need to know where to plug the 4 wires onto which of the 4 prongs on the new regulator and it should be ready to fire up and drive again.....
Old Sep 17, 2006 | 11:33 PM
  #29
Shifty101Easy
PS, i noticed two of the wires (1 red, 1 blue) go to the choke type thing on the carb...not the firewall.....the blue one just grounds on the firewall....and i dono where the red one should go....
another blue wire goes from the left terminal on the solenoid (+ batt side) to....???? i assume it would go to the "A" terminal as thats the batt terminal from what i can understand....
another one is supposed to just ground to the fire wall and go to a terminal on the voltage regulator....i dono which terminal though....
any help?
Old Sep 18, 2006 | 02:38 AM
  #30
Shifty101Easy
ok...now from extensive google searching over many hours i have come to the conclusion this little cube thing is probably a headlight relay....that isnt hooked up to any headlight wiring.......im baffled...i dont even know what to think???? helllllllpppppppppppppp
mtgldr
Feb 3, 2024 09:00 PM
Golfsito
Oct 6, 2015 11:02 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
