Noise Suppressors
Old Mar 28, 2007 | 10:37 AM
krobillard's Avatar
krobillard
Default Noise Suppressors
I have two of these noise suppressors, I was wonding if they could be causing me battery problems and can I remove them, one is on the voltage regulator and the other in on the alternator.
I know they are for the radio, but do they effect anything else?and is it worth replacing them, those little gems are 20.00 ea and three auto store around my area don't carry them.
Old Mar 28, 2007 | 11:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Noise Suppressors
You can take them off and it won't affect anything. If you have a modern radio and modern spark plug wires the supressors are not necessary anyway. Keep them in a safe place though. You may get a ton of money forthem on Ebay later on.
Old Mar 28, 2007 | 03:17 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
or you can preserve them and make your own all they are its 47µF cap you can go to your local electronics supply and get a few and but them in a project box and then that will work much better than the oe one cause it will cover a broad range of frequencies
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
ccdguy
Sep 19, 2015 05:20 PM
