289 Head Tightening sequence
Jul 15, 2007 | 12:10 AM
Still waiting on my shop manual to show up sooo....
Does anyone have the head tightening sequence for factory 289 heads?
Your help and reply is appreciated.
Jul 15, 2007 | 12:27 AM
RE: 289 Head Tightening sequence
You start in the midde and work your way out to the edge, then re- check and adjust it after you are done.
Jul 15, 2007 | 12:31 AM
Quote:
ORIGINAL: Soaring
Valve train middle bolt or outside middle bolt? I am guessing valve train middle.
Jul 15, 2007 | 12:36 AM
yepper
Jul 15, 2007 | 12:03 PM
It's a three step process - 50 ft-lbs, 60 ft-lbs then 65 to 70 from the middle out unless the head gasket or machine shop that did the heads gives you a different maximum.
Jim
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Sixer4Life
Oct 12, 2015 04:26 AM
kevsgt
Oct 9, 2015 10:12 PM
Drastang
Sep 30, 2015 03:48 AM
289 ,
289head ,
99 ,
bolt ,
cylinder ,
factory ,
ford ,
gt ,
head ,
mustang ,
pattern ,
sequence ,
specs ,
tightening ,
torque
