power steering problem
Old Sep 10, 2007 | 12:34 PM
hotrod351's Avatar
hotrod351
Default power steering problem
i have the power steering that has the control valve and the ram cylinder on a 1970 mustang. problem is that the pivot ball, which connects to the pitman arm, is sloppy in the control valve. is there a way of fixing this or do i need a whole new control valve assembly. thanks for any input on this.
Old Sep 10, 2007 | 02:05 PM
DonA's Avatar
DonA
Default RE: power steering problem
Define "Sloppy in the control valve"--The ball stud is held in the center position by two springs. The movement or lack of movement left and right is what determines how much assist you get. The higher the resistance of the wheels against the steering wheel effort, such as standing still and pulling the steering wheel full left or right the further the ball stud moves which in uurn moves the control valve furthur off it's center which increases the assist pressure.
Thisportion of the valve seldom goes bad if properly lubed but there iare kits available, or at least there used to be.
Old Sep 10, 2007 | 02:08 PM
jlg2002's Avatar
jlg2002
Yep, they make repair kits. go to NPD or your prefered vendor. $ 35 bucks for the std and 25 bucks for the socket at California mustang.
Old Sep 10, 2007 | 03:06 PM
hotrod351's Avatar
hotrod351
the slop is in the pivot ball. when my wife turns the wheel i can watch the pivot ball move back and forth quite a bit. i don't suppose it would be advise able to try and tighten the thing up. i can get the control valve and rod from checker for $238.00. problem is that i have never greased it, didn't know about it needing grease. the car has about 130,000 miles on it. everything else has been replaced, tie rods, lower a arms, upper and lower ball joints and idler arm. i don't know how long these units are suppose to last and the wife drives it to work every day, 50 miles round trip.
jpplaw
Mar 19, 2025 08:53 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
Cit95
Sep 22, 2015 07:08 AM
kdryan
Aug 29, 2015 09:57 PM
Tyoung68
Aug 25, 2015 04:31 AM
