steering wheel bushing
Old 10-02-2007, 12:23 AM
bradleyb
bradleyb's Avatar
Default steering wheel bushing
I am trying to put a new steering wheel on and think I must have lost a part somewhere - how can I get the steering wheel shaft to stay solidly in the center of column? There is a little bushing that holds the shaft quite nicely when it is pushed in all the way - my only problem is that it looks like it will vibrate back up and get loose - do I need to tap this bushing down harder with a hammer to hold it in place? Am I missing a sleeve/spacer that would hold this in place? I am putting a Grant steering wheel in with the adaptor on a 1966, here are some picks of the steering column and I have a pic of the bushing that I mentioned above (also, I have a rack and pinion steering).
Any ideas, been struggling with this for a few days, help[:@]
bradleyb is offline
Old 10-02-2007, 12:25 AM
bradleyb
bradleyb's Avatar
Default RE: steering wheel bushing
Here are the pics - 2 of the column with the bushing on it and 1 pic of the bushing itself, thanks
bradleyb is offline
Old 10-02-2007, 12:26 AM
bradleyb
bradleyb's Avatar
having a hard time with the pics
[IMG]local://upfiles/34309/D843EC81F4BC4D838425BDB242C7EF14.jpg[/IMG]
[IMG]local://upfiles/34309/9ABFF1B7EA5D4B25A580D3D3292DD1C1.jpg[/IMG]
[IMG]local://upfiles/34309/E990DF9235E74372BC98FB81CA57724A.jpg[/IMG]
bradleyb is offline
Old 10-02-2007, 12:27 AM
bradleyb
bradleyb's Avatar
I should also add that when I push this down onto the shaft (past the turn signal indicator), it then becomes snug like it should, thanks
bradleyb is offline
Old 10-02-2007, 01:22 AM
gothand
gothand's Avatar
I don't know about a Grant, but with the stock wheel you just push it in pop on the wheel and tighten it up. No problemo.
gothand is offline
Old 10-02-2007, 09:05 AM
xian67
xian67's Avatar
i installed a grant steering wheel on mine 67 coupe. it said you needed to cut the unused stub. but read the directions first if you havent.
xian67 is offline
Old 10-02-2007, 03:02 PM
jlg2002
jlg2002's Avatar
The bushing stays in place by the installation of the stock wheel.
jlg2002 is offline
Old 10-03-2007, 11:41 PM
bradleyb
bradleyb's Avatar
the bushing sits down on the other side of the turn signal indicator, I am still missing what holds the steering shaft in the center of the steering column - the grant piece is going to slide over the grooves and then I will tighten the steering wheel down onto this grant piece. I will give it a try tomorrow night to see if I am missing something
bradleyb is offline
Old 10-04-2007, 12:51 AM
JohnnyK
JohnnyK's Avatar
Are you missing the ridiculous bearing that no bearing factory has been able to find for me? what year?
JohnnyK is offline
Old 10-04-2007, 06:41 PM
bradleyb
bradleyb's Avatar
the car is a 66 coupe, i don't remember seein anything when I took this off and my computer crashed which had the "before" pics on it
bradleyb is offline
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: steering wheel bushing
