T-5 conversion parts PLEASE HELP
Old Feb 6, 2008 | 03:07 PM
  #21
Rorin67's Avatar
Rorin67
Default RE: T-5 conversion parts PLEASE HELP
That "sheild" is also called a blockplate.
  #22
choefle's Avatar
choefle
They are also called a block plate. Found this one on ebay.
Old Feb 7, 2008 | 02:46 AM
  #23
PONYBOY65's Avatar
PONYBOY65
[:@]DUH! thanks guys
Old Feb 8, 2008 | 05:07 PM
  #24
fordification's Avatar
fordification
crazy pricing, but everythings there.
its mostly the price of the tko.
Old Feb 8, 2008 | 05:23 PM
  #25
65Raven65's Avatar
65Raven65
fordification, do you have a link? What is the price for everything?
Old Feb 10, 2008 | 12:37 AM
  #26
fordification
http://www.keislerauto.com/ford/tran...65-70_auto.asp
4500, but dam, it eliminates the guess work.looks to be all but the pedals.
[ol][*]TRANSMISSION – Custom-engineered TREMEC TKO-500 (550HP) or TKO-600 (650HP). Every Keisler transmission offers a wealth of custom features that you won't find anywhere else, including:[*]Shifter location custom designed for your 1965-1970 Ford Mustang or Cougar. [/ol]
[ul][*]Custom short-throw shifter designed to provide better-than-stock shifting.[*]Custom shift position exactly the same as Toploader for zero tunnel hump modifications on most models.[*]Traditional Toploader bolt-pattern. [/ul]
[ol][*]ENGINE SPECIFIC INPUT SHAFT –– custom input shafts mean bolt up to any Ford Engine and bell housing (390,429,460,351,FE,5.0 and Mod Motors) with no adapter plate.[*]PILOT BEARING – Needle Roller Bearing for long life and high capacity[*]DRIVE SHAFT – High alloy steel balanced with premium solid sealed U-joints[*]CROSSMEMBER MOUNT – Heavy duty formed steel, gold anodized[*]ISOLATOR – Heavy-duty rubber isolator. Polyurethane upgrade available.[*]BACK-UP LIGHT WIRING HARNESS – easy coupling to factory wiring[*]NEUTRAL SAFETY START SWITCH – for automatic to 5-speed conversion[*]SPEEDOMETER OUTPUT – Mechanical speedometer cable and correct driven gear PLUS integrated 2-wire electronic output included. Optional correct wiring harness also available.[*]HARDWARE – High strength Grade 5 and 8 fasteners, properly sorted, bagged and labeled for easy reference[*]BELLHOUSING – Titanium-aluminum construction. (SFI steel available, ask for details.)[*]FLYWHEEL & CLUTCH KIT – Billet steel flywheel and modern effort Performance Clutch Kit (balanced Pressure Plate, premium Disk)[*]HYDRAULICS[*]REPRODUCTION BOOT, SHIFTER HANDLE AND SHIFTER PLATE[*]MANUAL – Easy to understand instructions; 8-12 hour installation[*]100% Customer Satisfaction Guarantee[*]6 month warranty – We DOUBLE the factory warranty and give you 2 years to activate AT NO EXTRA COST! (Warranty Terms) Full 1-year warranty available for only $60 extra.[*]The best Customer and Tech Support in the industry[*]Lifetime Tech Support from our premier experienced staff [/ol]
Old Feb 10, 2008 | 07:23 AM
  #27
leerocker's Avatar
leerocker
I'm attempting this same conversion and wondering about the pedals - can i just get the single clutch pedal and hook it up to the existing brake pedal hangar, or do i have to buy a whole new assembly with both pedals?
Thanks for any help!
Old Feb 10, 2008 | 11:43 AM
  #28
PONYBOY65's Avatar
PONYBOY65
im not to sure if you could do that, but i do know you could buy the entire assembly on ebay.
check it out
http://cgi.ebay.com/ebaymotors/1965-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Musta...spagenameZWDVW
Old Feb 11, 2008 | 05:01 PM
  #29
fordification
That keisler kit works out to be about $2000 for the tko-600. seems like a very nice setup to me.
Old Feb 11, 2008 | 05:25 PM
  #30
JMD's Avatar
JMD
Nevermind!!
