Carb problems after switching to 4 barrell
Old Aug 3, 2009 | 04:01 PM
boogerschnot's Avatar
boogerschnot
What type of cam do you have? Is your motor stock?
Old Aug 3, 2009 | 05:29 PM
blue 67 coupe's Avatar
blue 67 coupe
Yes for the most part the motor is stock. It's still running the stock cam since it said that for recommended use for dual exhaust, and an ignition system to run the setup. I just got a rebuild kit for it and plan on rebuilding it within the next two days. I will let you all know how it goes.
Old Aug 3, 2009 | 10:21 PM
fakesnakes's Avatar
fakesnakes
This has all the parts you need:
http://www.summitracing.com/parts/HL...9/?image=large
Good luck with your rebuild!
Old Aug 4, 2009 | 12:28 AM
blue 67 coupe
Thanks but I called around earlier and found a shop that had basically every part to a holley carb in stock. Bought a rebuild kit from them for $35.00. And the tear down and rebuild will be done tomorrow. Hopefully it will end all the problems I am having if not I guess i'll save up for a edelbrock 600 instead.
Tivo304
Aug 28, 2023 12:19 PM
articman
Jun 21, 2018 11:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
whatsup62
Sep 3, 2015 01:38 PM
cbird1177711
Sep 2, 2015 08:51 PM
