Mustang 289 with a Dual 4 Barrel setup
#21
That's what people can do now.
But it wasn't always so. I also remember very clearly seeing the 2 x 4 over-the-counter availability for the 289.
Carb size was most likely in the 375-ish range like these Carter WCFB models.
I once had a pair of those on a polyspherical-head Chrysler 318, which is not all that much more engine than a 289. Even though the secondaries were mechanical, they were staged, and with a progressive linkage between the two carbs driveability was not as bad as you might think.
Thumpin - with respect to the things that people tried and actually brought to market, do you remember the Man-A-Fre setup?
Norm
Norm
#22
I never knew of dual carbs on a 289, but I do remember the tri power set up. And ya I would think carb adjustment would be a nightmare.
I saw this car that recently sold in Jan 2011 on Ebay with a tri power set up.
http://cgi.ebay.com/ebaymotors/1966-...US_Cars_Trucks
#23
OK listen up, .040 289, FMS292 hyd. cam, Keith Black flat tops w-O gap ring, Edelbrock RPM 202 heads, Crane gold rollers, Edelbrock RPM air gap w-Holley 650 dp mechanical secondary, windage tray ect. Broke this in 3 months ago and was very impressed with the combination( in 63 factory 4sp T10 8"Trac lock w-3.25 geared Falcon Futura). Was offered a Edelbrock RPM air gap dual quad w- two Edelbrock 1404 carbs, installed them two weeks ago right out of the boxes with fixed linkage( non progressive) and I can tell you it this set up improved 2000 though 6000 rpm drasticly. No hesitation or stumble any where no matter how you mash the peddle. The BFG 235/60s are useless in first and second and marginal in 3rd and 4th. The right combination of parts or just lucky?
I will do know of a bowtie guy with Holleys and a tunnel ram that is about to throw in the towel though.
#27
#28
Most people who doubt the 2X4 setup have never driven one..These factory type setups are not to be confused with tunnel rams and big double pumper type race only setups..With a progressive linkage and vacuum secondary carbs they can actually be very streetable..In most cases a modern intake and single carb will make more power on todays street engines but the 2X4s are way cool looking on an old school muscle car..
#29
#30
