302 swap question
Old 08-15-2009, 08:35 AM
bookzguy
bookzguy's Avatar
Default 302 swap question
Is it common for someone to swap a 1993 mustang gt 302 engine and transmission into a 1965 mustang coupe? Also swapping the factory electronic fuel injection with a 4 bbl carb?
I'm just curious because I was talking to someone that claims he did this to his 65 mustang, sorry for the newb question.
bookzguy is offline
Old 08-15-2009, 08:37 AM
Starfury
Starfury's Avatar
Very common, and not difficult at all. The motor is essentially the same, aside from the pan, timing cover, and front accessories, and you can strip off the EFI stuff and drop a carb and intake on it with no trouble.
Starfury is offline
Old 08-15-2009, 08:46 AM
bookzguy
bookzguy's Avatar
Stripping the EFI and adding the carb, would that make it just as reliable?
bookzguy is offline
Old 08-15-2009, 09:51 AM
2+2GT
2+2GT's Avatar
EFI requires electric fuel pump and return system, and a stand-alone wiring and computer. Time and money. Putting a carb on the 5.0 is dead easy, and much less costly. I have started my carb'ed 289 when the snow was up to the door handles. If you have a manual transmission, you'll need a bracket for the equalizer (Z bar) where it attaches to the engine. Easy and inexpensive.
2+2GT is offline
Old 08-15-2009, 10:35 AM
THEBLACKSTANG
THEBLACKSTANG's Avatar
Please post up pics if you decide to do it.
THEBLACKSTANG is offline
Old 08-15-2009, 10:06 PM
OCHOHILL
OCHOHILL's Avatar
I am nearly done with my 90 gt 302 swap into a 65.
I bought a used 90 GT HO motor, I replace the timing chain, front main seal and rear main seal. I installed a front sump oil pan. I plugged the oil dipstick tube in the block with a wood dowel. I drilled a new dipstick tube hole on the passenger side of the late model timing chain cover and routed the dipstick tube behind the late model alternator. I kept the serpentine belt drive. I eliminated the AC and PS pump with a Trick Flow bracket that moves the belt tensioner to the driver side. I bought a used T5z tranny. I made my own tranny mount. I am now installing a MustangSteve clutch arm and clutch cable with the shaft bearing kit. (my car was an automatic)
I'll do a writeup soon when I get a little closer to completing the car.
OCHOHILL is offline
Old 08-15-2009, 10:10 PM
guybored
guybored's Avatar
Thats exactly what i am doing swapping from a 200 to a 5.0. I am keeping the efi stuff would be alot easier if I would of gone with a carb might of even been done with it. Efi is time consuming and a little frustrating. But I think I will enjoy it once it is done. Hopefully by the end of this year.
guybored is offline
Old 08-15-2009, 10:22 PM
67mustang302
67mustang302's Avatar
I have a 91 block in my 67. You either need the adapter bracket for clutch z-bar or go hydraulic(I went hydraulic). And either a fuel pressure regulator with a return, or if you pull the timing cover, just put the 2 piece fuel pump eccentric on the cam gear for a mechanical pump. Then you'll need a dizzy that doesn't run off a computer that has a steel gear to work with roller cams, MSD(since Crane went out of business) makes a fully digital setup with the dizzy, where you can select the mechanical and vacuum advance curves through a dial, and they're controlled electronically from inside the distributor. It also has a built in rev limiter. Then just swap intake/carb.
67mustang302 is offline
Old 08-15-2009, 10:49 PM
JamesW
Moderator
JamesW's Avatar
As you can see, it's a pretty common swap.
Check out my webpage for a few "how tos" on the subject.
jw
JamesW is offline
Tivo304
08-28-2023 12:19 PM
Galactic
04-29-2019 02:56 PM
04stangman
09-17-2015 01:45 PM
97SN95GT
09-13-2015 09:45 PM
Quick Reply: 302 swap question
