C80E head confusion
Old 08-01-2010, 01:10 PM
KMatch
KMatch's Avatar
Default C80E head confusion
I picked up a set of C80E heads but am confused on the specs. They have no 4V or double dots over the 289 and do have one M cast under a port with "4" under another, but they are closed chamber. They seem to contradict what info I've found about them. I haven't measured, but it appears they are the 54cc variety. Who has the real scoop on these? I also have to see if they have hardened seats as the PO had a bunch of work done to them.
KMatch is offline
Old 08-01-2010, 01:29 PM
2+2GT
2+2GT's Avatar
It sez here that the C8OE-M head is the garden-variety 68 289 2V head, with 63cc chambers and 1.78/1.45 valves.
2+2GT is offline
Old 08-01-2010, 02:27 PM
KMatch
KMatch's Avatar
QUOTE=2+2GT;7133124]It sez here that the C8OE-M head is the garden-variety 68 289 2V head, with 63cc [/QUOTE]
Exactly. So who can explain the closed chambers?
KMatch is offline
Old 08-01-2010, 05:11 PM
2+2GT
2+2GT's Avatar
Closed chambers were normal, even on 2V engines. That open chamber stuff didn't happen until 1972, when emissions regulations killed compression. And performance.
2+2GT is offline
Old 08-01-2010, 05:31 PM
KMatch
KMatch's Avatar
OK, so you can get 53, 54 and 63-4 CC all in closed chamber?
KMatch is offline
Old 08-01-2010, 07:16 PM
2+2GT
2+2GT's Avatar
Yep. Don't forget the early 289HP, 49.2cc.
2+2GT is offline
Old 08-02-2010, 07:27 PM
KMatch
KMatch's Avatar
Does anyone see what I'm questioning? I agree, the data says these are 64cc heads and I'll check them should I ever get a moment to breathe, but who can argue the port shape is the same as the 54cc 4v heads, even though these obviously aren't 4v heads. That's why I ask "what's going on here?" My ports are the same as B to me. The pics suck as they are reduced, but my chambers have the downward left side sweep as in B and not the symetrical shape as in C. Can anyone argue that? Like I said, I'll whip up some CC tools just for grins. Something just doesn't add up to me with the numbers.
KMatch is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: C80E head confusion
