Help with swap
Old Aug 23, 2018 | 09:35 AM
Old dogs new tricks's Avatar
Old dogs new tricks
Default Help with swap
I have a 67 mustang, I had a 5 speed put in from a 97 5.0, my car was originally automatic, now my clutch pedal is way to low and I am told no adjustments??? It is a cable style clutch. Suggestions?.
Old Aug 23, 2018 | 10:15 AM
MonsterBilly's Avatar
MonsterBilly
sounds to me like they installed a hydraulic clutch. It can be adjusted if it was done correctly. There should be a shaft going from the slave cylinder to the lever. Unless they installed a hydraulic slave throwout bearing. In that case, it cannot be adjusted unless the mounting point from the lever to the pedal is changed
Old Aug 23, 2018 | 01:48 PM
Old dogs new tricks
I'm not real versed on the different clutch set ups. This does not have a hydraulic (oil filled) canister .the cable comes from beside the bell to the fire-wall and mounts to the pedal
Old Aug 23, 2018 | 09:37 PM
Gun Jam's Avatar
Gun Jam
can you post a pic of this low pedal?
Old Aug 24, 2018 | 02:23 AM
1slow67's Avatar
1slow67
ROTM Moderator
Makes me wonder if they didn't put in the pedal return spring.
Old Aug 24, 2018 | 10:13 PM
imp's Avatar
imp
'97 5.0? The last Mustang 5.0 was 1995, after that, 4.6L. imp
amvaughn
Aug 19, 2013 07:44 PM
jlelectric
Jan 22, 2013 01:38 PM
partsguy329
Jul 24, 2011 02:46 PM
05gtgreen
Apr 19, 2011 08:26 PM
00blackstang
Mar 16, 2007 12:25 PM
