Bendix issue
Old Dec 4, 2022 | 11:21 AM
timnoles's Avatar
timnoles
Default Bendix issue
Long story short. 1964.5 Mustang. 260 V8. Had the engine rebuilt about 1,000 miles ago. Had the transmission rebuilt about 500 miles ago. Battery is new.
Went for a drive the other night and stopped and started a few times. Last time I cranked it I got a high-pitched whirring sound but no engine crank. Jumped the battery but no luck. Towed home.
Today, I pulled the starter (not easy with headers). The Bendix gear is completely worn down about 1/8 front the top (engaging) area of the gear.
i know I need a new bendix gear, but is there a way to adjust the length of the throw so a larger part of that gear engages?
is there a mini starter for the 260 V8 anyone likes or have had luck with? Thanks
Worn bendix gear.
Flywheel looking ok.
Old Dec 4, 2022 | 04:29 PM
imp's Avatar
imp
Worn bendix gear.
You may have the wrong starter, bendix drive gear too big to engage ring gear.
Old Dec 5, 2022 | 10:52 AM
Crazy Fred's Avatar
Crazy Fred
Maybe the starter needs to be shimmed. That gear is shot.
Old Dec 9, 2022 | 11:03 PM
Gun Jam's Avatar
Gun Jam
Shims would probably make it shorter and provide even less engagement. I also suggest checking for correct starter. I know with the 302 this can occur with at least some after market mini starters but in my case it was so far off the teeth didnt even touch.
Old Dec 11, 2022 | 10:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
That’s throwing in superfar it’s worn on the face past the teeth even.
Old Dec 11, 2022 | 10:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Also when I put a starter on my 65 fastback I actually had to get a starter for a 64 falcon because the 65 starters didn’t fit properly
Mmathews506
Feb 2, 2016 05:13 PM
bfarra
Feb 13, 2015 11:00 AM
beekay562
Aug 9, 2012 11:48 PM
kalli
Apr 13, 2011 10:28 AM
e40water
Jun 1, 2004 03:30 PM
