Claybar failure
I also have those white specs I only get them off with my fingernails lol. I am weary of wet sanding my clearcoat -.-. Also careful with gooze-off dont leave it there for long it stained my rear bumper. But I also forgot to clean the dribs after i finished cleaning my tail light so maybe the overnight soak could have been the culprit...
Andrew
Andrew
When you say white pecks 2 things come to mind. if its on your hood it could very well be lil rock chips from driving. Plus think bout it if you have chips that are deep enough when you rub your clay over it it could be getting caught in the nick causing the white spec. just a thought.
White specks sometimes appear if you travel in close proximity to a DOT line paint crew. The best results I've had is using a PLASTIC scraper with Stoner Trim Cleaner and TurtleWax Bug and Tar Remover. Please make sure that the scraper is the type used for in-home wallpaper removal and it shouldn't mar the paint or clearcoat.
Question - Why 2 threads for the same issue? "Claybar Failure? - Or - Not a Claybar Problem???
Very serious issue???? Try 3 or 4 threads dude.
Sorry - just wasted my time. My bad.
So last month I used the meguiar's claybar kit to do my car. Definite improvement.
However, there are several things that I have been unable to take care of. I have some small white specks that have bonded to the paint. I have no idea what it is but I can feel it when I run my finger over it. The claybar didn't take it off and neither does washing the car with no rinse or meguiar's gold.
There are also some stains on the paint. I have no idea what the hell it is. Tree sap maybe. Who knows. But the clay failed to remove it as well.
What can I do about this crap? Will it take a polish to remove it?
) and a white powder flew all over the car when she drove by it. That white stuff is a combo of cement dust from the cutting and the water (or whatever is used to cool the blade) and the sun and heat from the engine bay baked it right in the clear. So I said let me grab my clay and see what I can do.....well the clay from Meguiars clay kit (white clay=fine clay) did not do a damn thing for me. So I headed to the auto parts store and bought Meguiars Mild clay (mild=blue and in a plastic can) and it worked but it took me three times as long to do the car and the stores closed and in hindsight the aggressive would have cut that time in half. I was to the point that aggressive clay would work best....Meguiars makes that too and it is better than removing clear from a car that doesn't have much clear to begin with. I would not wet sand the car unless you know what your doing and have practiced on a car of lesser value.....JMO
Sorry don't know how to remove, but I had similar white specs when I had my 06 BLACK GT. I think they are really obvious on a black car. Anyways I was told by other forum members it is possibly iron or metal contaminant from shipping. I have no idea how true that is, but may help you go in a different direction for possible removal
I can say without a doubt that any and all new cars should be clayed after you buy new....why you might ask? How do you think the parts and cars get delivered to and from the factory and to dealers with the finished product? Some by truck transport and many factories will have the parts shipped via train to the factory itself. The cars once done can sit in the back lot (by the railroad track leading to the factory) awaiting delivery to the dealership or on the dealer lot out in the open exposed to anything that can and will contaminate the paint for weeks or months.... I have been detailing for 17 years and swear by few things and clay is one of them
link for the aggressive clay
http://meguiarsdirect.com/detail/MEG+C2100
link for mild
http://meguiarsdirect.com/detail/MEG+C2000
expensive for something that looks and smells like kids play dough (spelling?)
but better than re-clearing the car (or spot clearing) and the time involved with finding a trusted and fair paint and body shop.
Hope this helps everyone.......remember least aggressive to most aggressive
ex- bug and tar remover, then fine clay, mild, and finally aggressive clay. after that wet sanding and buffing to get any sanding marks out of the paint. Practice makes perfect! Keep some of each on hand and you can do many cars with just one so spread out the cost over a year and it is pennies compared to a repaint which could cost hundreds or thousands.
Sounds like you were driving behind someone after road lines got painted. It's might be white line paint kicked up unto your car. Have your tried bug/tar remover first? If you had a decent coat of wax on your car, bug/tar remover might take it off before you try wet sanding.
-10 on Dry Eraser, I have seen them scratch clearcoats to hell and back.
