Timing, Mods, & Year
Old May 28, 2004 | 05:53 PM
  #21
Obsol3te's Avatar
Obsol3te
Default RE: Timing, Mods, & Year
heh, you guys are going two different ways with this...
My engine does have around 120k miles on it, so there prolly is some buildup
I'll just bring timing up to 12 and leave it at that, seems safe enough.
And I'll continue to use 93 Octane, Sound good?
Old May 28, 2004 | 06:22 PM
  #22
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Use what you wish, but I can assure you its best to use the lowest octane rating needed to prevent pinging. If you want to know why, just let me know. I'd be glad to type up an essay on it if your still unsure. By no means do I expect anyone to blindly take my word for it, but if your unsure then do some independant research and decide for yourself whats best.
Old May 28, 2004 | 08:43 PM
  #23
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
I GOT A CARB SYSTEM ...I GO FOR 18 BUT RUN RACE GAS ,,GIVE IT GOOD RESPONSE,,BUT ITS THR TOTAL YOU WORRIE ABOUT,,,I LIKE MINE AT AROUND 34 TOTAL OF NO NOS USE,,,,.I RAN 16 DEG ILDE,,AND 34 TOTAL WITH MY OLD MOTOR WITH PUMP GAS ,,YOU HAVE TO TAKE IT OUT OF THE DIST ON MINE ,,,DOES THIS MAKE ANY SINCE TO YOU ,,OR M I TALKING GREEK,,,BUT MY MOTOR ITS ALLWAYS AT TOTAL TIMING AFTER BURNOUT ANYWAY...
Old May 28, 2004 | 09:18 PM
  #24
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
people don't set total timing in their backyard though NOS/MAN, let alone 50*
but umm yea 18* initial is a sh!tload, no way can it be done on pump gas
Old May 28, 2004 | 09:33 PM
  #25
Iamopie2's Avatar
Iamopie2
Im new to this timing thin...like everything else it seems, haha... can someone humor me and explain how you would adjust your timing with say a steeda timing setup thanks a lot...im learning a bunch
The Army Guy
Old May 28, 2004 | 11:51 PM
  #26
Obsol3te's Avatar
Obsol3te
Dunno what a steeda timing thing is, but Alls ya need is a Timing Light, and a wrench to loosen your Distributor Bolt.
Oh and a breaker bar and socket to turn the engine over.
Old May 29, 2004 | 02:16 AM
  #27
Obsol3te's Avatar
Obsol3te
ORIGINAL: NOS/MAN
So how do you set the TOTAL timing?
Old May 29, 2004 | 03:51 AM
  #28
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
ORIGINAL: Obsol3te
ORIGINAL: NOS/MAN
well you to find out your intial timing first..what its happy at with the fuel your running,,i like to get as high as you can before pinging do it by hear turn tell you hear than back off till it stops,then check it to see where it is,,,...okay to check you r total timing you will need a adjustable timing light..one with a dial on it,,rev. motor untill your timing mark dont move anymore,,say around 3000/3500 depending on dist advance springs.....okay rev motor with the timing light going looking at the timing mark..when it stops advanceing ,,keep motor reving turn dail on timing light untill mark lines up at top dead center,,,,I USE MY TEETH TO TURN IT WITH WHEN REVING UNLESS YOU HAVE 2 PEOPLE,,UNTILL TDC THAN .then see what your total timing is,,,if you have 14 at ilde and 42 total ,,say your motor likes around 38 you will have to take it out of the dist. if you retard your timing to get 38 total you will have 10 at idle......MAKES ANY SINCE AT ALL???
Old May 29, 2004 | 10:56 PM
  #29
Obsol3te's Avatar
Obsol3te
Kinda...
I got a timing light with a dial on the back of it
So you want me to Have someone sit in the car, rev it to 3,000 and hold it there.
While I try and set the distributor so its at 38º when its being revved?
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
Calizic
Aug 28, 2015 01:46 PM
SterlingStunner
Aug 27, 2015 11:33 AM
Soldier GT
Aug 12, 2015 03:46 PM
