rubber gromet in firewall
Is there a special tool to run a wire thru the gromet in the firewall. I need to run a ground to the engine block for some of my gauges and that what autometer suggested. ANy tricks to getting this done without damaging the gromet.
RE: rubber gromet in firewall
You don't really need a gromet if the wire you're running through the firewall is a ground wire(?) I mean, even if the wire does "short out" at the firewall, the firewall is also a ground lol
What I meant by a special tool, maybe a coathanger to pull it thru, or something that works without shreeding the other wires How do you push the wire thru the gromet ???
jwog666
12-27-2021 08:09 PM
