Starting trouble !
Old Nov 11, 2008 | 04:27 PM
sixtsixstang302's Avatar
sixtsixstang302
Default Starting trouble !
OK. 302 4-speed in a 66 coupe. Car was running a year ago and burnt up dash harness. New harness is installed. Engine fired up yesterday with difficulty. I went to check timing and it was 40 deg +. Turned on timing light, retarded timing, light went out. Engine would only start when timing was extremely high. With timing turned down, car ran swell except for exhast leak. Today, engine will not start. It acts like it wants to but just won't catch. TDC matches #1 cylinder on compression stroke. Firing order is currently 15426378. Fire (Pertronix) and fuel (650 Speed Demon) are functioning. Any thoughts are appreciated.
Old Nov 11, 2008 | 04:36 PM
Stepman's Avatar
Stepman
...Can't happen. I'm thinking if you got fire and fuel, it should start. I suspect a bad coil wire.
Old Nov 11, 2008 | 04:42 PM
sixtsixstang302
coil wire is good.
Old Nov 11, 2008 | 04:47 PM
Stepman's Avatar
Stepman
Not to be a smart ***, but, how do you know for sure? I have seen vehicles that won't fire until you advance them but, once running, you set timing and by turning the wire, you break the connection.
Old Nov 12, 2008 | 06:50 AM
sixtsixstang302
If you broke the connection in the coil wire while the engine was runing, wouldn't you lose spark and the engine stop?
bjdutch2005
Mar 24, 2017 03:38 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
