What would handle more boost? 5.0 or 4.6
#32
If you get that 4.6. Unfortunately there were quite a few variations & not all will hold the same in stock form. Same for the 5.0. Some engines it makes a big difference while one may be safe at 25psi, another variation could be lucky to hold 5psi. Also the psi it will hold will depend on quite a few factors.
#33
Yea I have been tuning dsm's for years now and thats what I do. I was just saying letting you know what stoich on e85 is. I run 16.1 afr at cruise/closed loop. At wot/open loop I run 11.1-11.5 gas equivalent. I have always liked my lean burn tune for gas mileage expecially when I lost 20% gas mileage switching to e85.
I dont know if its just us 4 cylinder guys but Ive seen burnt valves at 12.1 afr's at least on pump gas. But that is at 35+ psi making lots of power. We usually stay under 11.5 to be safe. Plus the dyno doesnt net much gain from going a little leaner. More boost and richer tune always nets more power then less boost and leaner tune.
#34
brain and keyboard not in sync
WHOOPS I know that but whoops typo, hhaa ha I contradicted myself
forged pistons will last longer than cast pistons under non-optimal conditions
Originally Posted by myself
the hyper 93
1985-1993 HO have forged
#35
My old 07 GT, which is still in the family(GF Owns it now) has been daily driven with almost 12PSI. Down to the number, it runs 11.39 PSI. So, depending on the amount of boost, and the setup, the 4.6 2V or 3V can handle as much boost as the 5.0, if not more.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
