Trouble starting
Old Jan 11, 2010 | 07:00 PM
rygi23's Avatar
rygi23
Default Trouble starting
My friend's '04 Mach, trying to help a brother out. Car turns over in the a.m. when it's cold but will not start until it warms up in the afternoon. I was thinking the battery dropping a cell (still on the factory one @ 80K!) but the car is turning over strong as if it's not getting fuel. He is throwing the o2 code (o/r h with no MIL elims) but we're foggy on how that would have an effect. Any help greatly appreciated.
Old Jan 15, 2010 | 07:51 PM
MustangBradley's Avatar
MustangBradley
Bad fuel pump? In the morning, can you hear the fuel pump pressurize the system when you first turn the key on? You should hear it plainly make a noise for about 2 seconds then stop. If you don't, then I would bet the pump is on its last leg.
Old Jan 16, 2010 | 11:25 PM
rygi23's Avatar
rygi23
Nope. That was my 1st suggestion but he said he could here it.
Old Jan 17, 2010 | 09:49 AM
MustangBradley
I think you are on the right track with suspecting a fuel problem. Next is to check the fuel filter. Also, bad gas could cause problems though bad gas is less of a problem these days. My 5.0 would not start with the tank low once. I added some new gas and it started up. I went to the gas station, filled up and the problem never resurfaced. It acted like it was out of gas but I could hear some sloshing around.
Old Jan 17, 2010 | 11:25 AM
Doc Hawk's Avatar
Doc Hawk
What do your plugs look like?
Old Jan 17, 2010 | 03:04 PM
Detailer_Dave's Avatar
Detailer_Dave
The IAT sensor could be out of spec and not enriching the fuel enough to start engine at real cold temps.
Old Jan 17, 2010 | 06:58 PM
Snitz's Avatar
Snitz
what is the actual error code
bjdutch2005
Mar 24, 2017 03:38 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
