hanging RPM during shifting
Old 08-05-2005, 09:28 PM
greenonegreg
greenonegreg's Avatar
Default hanging RPM during shifting
[:@] my Engine RPM is not going down, or very,very slow, to idle when i release the accelerator Pedal for shifting.
The Ford dealer told me this is normal on some 2001-2003 V6 Models.
I cant beleve that and i hate it.
What can i do.
Please help[]
greenonegreg is offline
Old 08-05-2005, 09:32 PM
The Great Cornholio
I ♥ Acer
The Great Cornholio's Avatar
Default RE: hanging RPM during shifting
IAC restrictor plate
The Great Cornholio is offline
Old 08-05-2005, 10:28 PM
Chopper
Chopper's Avatar
Go to your freindly neighborhood hardware store and buy a 1/2 inch copper pipe cap.Go home and take a 3/16 inch drill and make a hole in the center of the cap.Pull the IAC hose off the throttle body and slide the pipe cap inside.Replace the hose.Start the car and turn on the AC.If the idle is too slow you can enlarge the hole untill the idle speed is to your liking.I have mine set at 850-900 rpm.It also helped the manual trans.shift smoother when cold,and hot,for that matter.(in my case anyway)Total cost $.29+your time,about 30 mins.
Chopper is offline
Old 08-06-2005, 01:36 AM
greenonegreg
thanks fo your help but what and where is IAC restictor plate,
Old 08-06-2005, 02:49 PM
greenonegreg
the V6 does not have an 1/2 inch Tube on the IAC !!
Does somebody have an other Idea to fix my RPM Problem?
Old 08-06-2005, 03:26 PM
99saleen351r
99saleen351r's Avatar
Sometimes freeing up the air intake will help that also
99saleen351r is offline
Old 08-06-2005, 04:48 PM
The Great Cornholio
I ♥ Acer
ORIGINAL: greenonegreg
http://forums.stangnet.com/showthread.php?t=470711
Look at that thread to get an idea of what an IAC restrictor plate looks like. Although your IAC is probably shaped differently that those on the '99+ V8s, and you therefore wouldn't be able to use the pre-made ones shown there, the principle is the same. Take your IAC gasket, or buy a new one (about 50 cents), and use it as a template for a piece of sheet aluminum. Drill both mounting bolt holes and one 1/2" hole as per your gasket, and where your gasket has the other 1/2" hole drill instead a 9/32" hole. Cut the aluminum to the outer shape of your IAC and you have an IAC restrictor plate. I used two gaskets, one on either side of the plate, when I mounted mine. Note that you may have to enlarge the smaller hole in 1/32" increments until you find the idle drop you like for your particular car. I had to enlarge mine to 5/16" and finally to 11/32" before mine was just right. Enjoy!
Old 08-06-2005, 07:13 PM
greenonegreg
Thank you guys,specialy to "the great cornholio",
i did what you told me, i made an IAC restrictor Plate, drilled an 5/16 hole insted an 1/2 inch Hole and i got it .
My RPM comes down like i want it.
Thank you for your help.
If you ever are in NM,Alamogordo, come by and have Drink with me !!!!!!!!!!!!!!!!!!!
Old 08-07-2005, 12:42 AM
The Great Cornholio
I ♥ Acer
Will do, glad it worked. I've ben using one for over a year and it made a big difference. I have had some work out at WSMR occasionally and was last in Alamogordo about a year and a half ago. I also go to Gallup once a year around Feb or March. NM rules, my second favorite out-of-state place to go after Las Vegas.
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Thunderball
15
11-22-2015 11:49 PM
Explosive
10-02-2015 07:45 AM
Florida Regional Chapter
09-30-2015 08:04 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: hanging RPM during shifting
