Brakelights/turn signals went dead
Suddenly while driving down the freeway I noticed that my turn signals stopped working. Once I got home I noticed that my brake lights as well as the hazards don't work either. Tail lights come on though.
Can't find any burned fuses or bad relays. Where is the one fuse for the brake lights? Where is the one relay for the turn signals?
Anybody else had this problem?
Thanks guys
Thanks guys
According to the following diagram labeled as a 04 Mustang 3.8,position number 41 in the fuse panel is power for the multifunction switch & brake lights.The multifunction switch is the lever used for the turn signals,so I would check this fuse first. Flashers are also in the fuse panel at position 13 & 19.
