Rear axle question?
Old Oct 4, 2019 | 09:22 PM
raguza123's Avatar
raguza123
Default Rear axle question?
I had a leak in the bottom of the axle houing cover so I had to pull it and clean it up and install a gasket that was not there and fresh 75w140 syhthetic oil, the question is I noticed the ring gear had a 373 cast on it, was wondering if it still stock rear with 327 gearing or does the 373 mean it was replaced with better gearing?
Old Oct 4, 2019 | 10:53 PM
imp's Avatar
imp
I have never seen a ring gear stamped with a gear ratio, simply because the ring gear having that number of teeth could also be used with a different pinion gear, thus giving a different ratio.
To be certain, check the vehicle ID on the driver side door jam. Under "axle" copy the code and search it's meaning.
Old Oct 5, 2019 | 08:31 AM
raguza123's Avatar
raguza123
Thank you, I did, was wondering what the 373 stood for, forgot to count the gears while it was open, the door tag says 327 for gears.
torchred5.0
Feb 4, 2012 11:51 PM
4bang93stang
Sep 14, 2006 02:19 AM
KillSwitchNY
Apr 6, 2006 04:02 PM
ihrdthattoo
Sep 8, 2004 09:39 AM
turbinesurgeon
Mar 10, 2004 01:51 PM
