Meziere Water Pump vs Underpulleys
Has anybody ever dynoed and compared the following two setups:
1) Meziere Water Pump (11-14 hp) and Steeda Underdrive Crank Pulley (? hp)
2) Steeda Underpulley set (2 piece) (crank and waterpump) (10 hp)
I'm very curious, because I don't believe I've seen anybody with the option 1 setup. The Meziere is $330 and Steeda Underdrive Crank Pulley is $170 ($500). The (2 piece) Steeda Underpulley is only $209. I'm wondering if it's worth the extra $300. Do you think the Crank Pulley would get you another 8 hp?
With labor I'm guessing option 1 would be over $700 total and option 2 would be about $400 total.
both would take less than 2-3 hours. i did both, very happy with both upgrades.
to do the UDP you just need a chrysler pully puller, they are not expensive and some auto parts places will loan them to you.
please dont waste your money paying someone else to do it.
dont forget you will need a shorter belt also if you do both. brenspeed has the shorter belt.
jwog666
12-27-2021 08:09 PM
dyno, electric, horsepower, meizere, meziere, mustang, pulleys, pully, pump, steeda, underdrive, underpulley, water
