Engine Oil Temp Sensor Location
Old Dec 31, 2022 | 11:01 AM
derek_clapton's Avatar
derek_clapton
Default Engine Oil Temp Sensor Location
Hi all,
I recently had to have the rear main seal replaced in my ‘06 GT. Since I got it back it is throwing code PO197: Engine Oil Temperature (EOT) Sensor low input. I can clear it and it will stay cleared until I turn the car off and back on.
My primary question is: where is the EOT located?
I’ve searched the internet pretty hard and I can find lots of info on the Oil Pressure Sensor, but essentially nothing for the Temp Sensor.
Thanks in advance for any good info
Old Jan 1, 2023 | 09:05 PM
HypromanGT's Avatar
HypromanGT
TL;DR: It's likely located on the side of the oil pan.
The sensor is referenced in the service manual for diagnostics here, but all mentions to replacing it point to section 303-14. I scanned through all of that and didn't see any mention of it, which is interesting. It's probably in the wiring/connector sections...somewhere. Maybe.
This guy had to unclip at least one plug from the oil pan before removing (at about 6:20); I suspect that might have been it:
And finally, there's this post that refers to it.
06whitegt
May 14, 2023 05:31 PM
styx21
Jan 22, 2015 09:52 PM
adidasUNT8
Jun 25, 2011 08:55 AM
stdyhand
Feb 23, 2011 07:57 AM
goharv
Oct 1, 2008 02:12 PM
