Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here.
Z28!
Old Sep 16, 2006 | 11:11 AM
  #61
98LS1's Avatar
98LS1
Default RE: Z28!
Holy misinformed batman!
I would go into a whole speel about it, but just check the sticky at the top of the page called "LS1." It should explain A LOT to you.
Camaro's are lighter generally. TransAm's/WS6's were typically the more "luxorious" cars vs the Camaro's. More crapolicious luxory = more weight.
Old Sep 16, 2006 | 12:47 PM
  #62
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Z28!
ORIGINAL: whiteout 5.0
check the track tests of a WS6 Trans AM '99
and an SS Camaro '99
check the curb weight I'll bet my Mustang the WS6 will be lighter and faster. The T/A WS6 is a slightly quicker car in the 1/4 check it out i know someone can pull up a link around here someplace for me.
Shut up newb, your just owning yourself with all your misinformation. Tommy was right in all his posts and you were wrong, sorry it's just the truth. I have been through this too many times on this site and really don't care to get into it with you.
Old Sep 16, 2006 | 12:54 PM
  #63
TommyV8's Avatar
TommyV8
Default RE: Z28!
13.5 for a 6-speed 3.42-geared 2000 Trans Am? 13.7 for a '98 Z28? What tranny was the Z28 tested with? Your sources suck, 5.0. My sig contains numbers that I actually ran in the car that I actually own and drive every day. And my 13.52 (in a 2.73-geared auto, mind you) came with more-than-ideal tirespin; my girlfriend cut a 2.0 in her stock 2.73-geared automatic '01 Z28 and ran 13.36 @ 105. It actually happened, in April 2004 at Gateway International Raceway near St Louis. Just accept it.
Old Sep 16, 2006 | 01:02 PM
  #64
grabbem88's Avatar
grabbem88
Default RE: Z28!
let me drive your car tommy..i'll get that thing in the 12's...you suck at driving an auto...BTW only "GOD" know's how to drive a ls1 anything.
j/p with ya.except the "GOD" part.
Old Sep 16, 2006 | 01:09 PM
  #65
TommyV8's Avatar
TommyV8
Default RE: Z28!
When I get my header leak fixed (and hopefully some sticky tires) I'll let ya take it down the 1320 Art, seriously. It may not be until next season though because I just ran across a good deal on some wheels and tires.
Old Sep 16, 2006 | 01:12 PM
  #66
grabbem88's Avatar
grabbem88
Default RE: Z28!
i think oct is the last month anyways.
i want to take my cousins T/A out,but he's too chicken shiat to really race it...although it's a 96 "ugly"...i'd still take it....
Old Sep 16, 2006 | 01:14 PM
  #67
grabbem88's Avatar
grabbem88
Default RE: Z28!
hell ya i'll race yours!....if you can launch mine without killing it.... GO FOR IT!
  #68
xxkazp3rxx's Avatar
xxkazp3rxx
Default RE: Z28!
Ok, im sticking my nose in here for 1 thread, lol...
I'd rather a LS1 Fbody auto over a manual anyday of the week. Most Fbodies i've seen local that were manuals, and built (inc gears) without a built axle, needed a new one very soon... I've seen auto's with stalls, gears, the works with stock axles run in the mid to low 12's... I believe the auto was a no cost option for the Fbodies which makes them much easier to find then the m6 (correct me if im wrong fbody guys). I also believe the GM auto is better then the M6... I know the LS2 GTO's autos actually run FASTER then the Manuals - well if you can launch em without getting completely sideways that is ).
2000 Trans-Am Formula: Curb Weight: 3341 lbs.
2000 Trans-Am: Curb Weight: 3397 lbs.
2000 Camaro Z28: Curb Weight: 3306 lbs.
2000 Camaro Z28 SS: Curb Weight: 3306 lbs.
-Source www.edmunds.com
EDIT: btw, I had a 3.90 geared, suspensioned bolt on 04' 2v and I would win about 3/4 of the Fbody races I raced. The ones I lost were normally not stock Fbodies, or just outdrove me... lol - I wouldn't say I "hooked" better then them, but I definatly instantly got 1-2 cars off the line on em, stupid LS1 top end.
Old Sep 16, 2006 | 02:06 PM
  #69
whiteout 5.0's Avatar
whiteout 5.0
Default RE: Z28!
Wow I'm surprised, yea i made a mistake the trans am ws6 6 speed is lighter....than a z28 automatic, I was misinformed. And sure the trans am is slightly faster than the camaro or whatever you think the case may be and I'll probably stand alone on this one but the camaros are FU**ING ugly man. Why would chevrolet make an ugly car for an ls1? Integrating the side mirrors with the body? Maybe thats why camaros also came in purple. I'll lose in a rusted 5.0 mustang than win in a ls1 or a lt1 camaro. I've got to much pride to let myself drive a camaro. And it's not b.c. I'm a die hard Ford guy, I'd drive a Trans AM Ws6 any day of the week, even the under rated LS2 GTO. No matter how much you try and explain it to me
Camaro's just suck man sorry.-just my 2 cents
Old Sep 16, 2006 | 02:22 PM
  #70
TommyV8's Avatar
TommyV8
Default RE: Z28!
I will concede that the Trans Am is the prettier car. I bought the Camaro becuase it was cheaper and had the same powertrain; I'm not about to spend thousands of dollars on aesthetics that could otherwise go into performance mods. I'm broke enough as it is.
