SVT Forums
Compound Boost Setup
Old Feb 28, 2010 | 07:04 PM
  #71
DarkDigital's Avatar
DarkDigital
Doesn't really matter when you're motor and tranny limited.
Old Feb 28, 2010 | 09:35 PM
  #72
Fobra's Avatar
Fobra
Banned
Originally Posted by mfj
Eff ALL of that ****! Wire up a window switch, and spray the bitch with a 75-100 shot, till you hit at least 10lbs, and let the turbos take over from there. Even in a sequential kit, the smaller turbo, is still limiting the big one, fyi...
Actually not really, yes there is a little restriction. But in the systems those companies use, they have used the wastegate as a bypass. At a given PSI it opens and diverts the flow to the larger turbo, (hypothetically) the smaller turbo only consumes the most amount of pressure it needs and the air flow takes the path of least resistance. These are the most impressive kits that I have seen thus far. They also have a diverter value on a dual scroll turbos that closes one scroll and then opens at x psi, essentially making a single turbo two (one small and one large). Of course the simple answer is running a computer controlled variable vane... but the technology for street cars is not here yet.
Old Mar 1, 2010 | 09:09 AM
  #73
mfj's Avatar
mfj
Banned
So in other words, YES, lol... More power would be made without that smaller turbo in place...
Old Mar 1, 2010 | 10:39 AM
  #74
Fobra's Avatar
Fobra
Banned
I would say yes, obviously... but not its not nearly as restrictive as say a supercharger after the turbo would be. I mean, I just saw a dyno where they hit around 1000 with it, but the curve is beautiful, progressive from 2000-7000 on hp and tq. But also remember that these are rice rockets and just having the large turbo for them leads to "supra syndrome".
Old Mar 1, 2010 | 01:18 PM
  #75
1SVTLVR's Avatar
1SVTLVR
Originally Posted by Gearhead559
could not have said it better myself.
the main reason i never post on corral, cause there always seem to be some dumbass , that has worked e7 heads, and his car runs 10's with no other mods.
LOL I don't know what you're trying to say but I run ported e7's on my 4.6 and have had amazing luck with that setup......well that and my skunk intake manifold...runnin' 9s lemme tell ya! haha
Old Mar 1, 2010 | 11:46 PM
  #76
mfj's Avatar
mfj
Banned
True, a sequential system is a lot more efficient than a supercharged/turbocharged compound system.
Old Mar 3, 2010 | 11:33 AM
  #77
DarkDigital
Got the meth installed yest. Still have to mount the nozzles.
Old Mar 6, 2010 | 02:32 PM
  #78
Mustang3GT07's Avatar
Mustang3GT07
So I just got done watching your video in the street/strip section. You said your car only makes 600rwhp?
Old Mar 6, 2010 | 03:29 PM
  #79
DarkDigital
Ya makes around that on a dynojet on 16psi right now.
Old Mar 7, 2010 | 10:54 AM
  #80
mfj's Avatar
mfj
Banned
And your efficiency is only going to keep getting LOWER AND LOWER, with the more boost you compound...
