transgo shiftkit
Old Jan 23, 2007 | 08:15 PM
BillyBobJoe's Avatar
BillyBobJoe
Default transgo shiftkit
earlier i said i recomend taking the kit to a pro, well, I called like 4 shops near me and none of them would install the kit. so i actually borrowed the tool i needed, a snap ring tool, from my gf's dad, and I'm gonna give it another shot on Thursday. I should have enough time and light since I now know exactly what to go for and unbolt, etc. Friday I'll be hitting the drag track, i hope...and bringing along my nice new Brenspeed tune. i'll let you all know how the times go and whatnot.
Old Jan 23, 2007 | 08:27 PM
98Ga's Avatar
98Ga
Default RE: transgo shiftkit
how difficult is it to install
Old Jan 23, 2007 | 11:34 PM
BillyBobJoe
hmm...i cant say accurate time figures but i'll give it a try. mind you i did all this while the car was still pretty hot. I had let the car sit for like an hour, but even like 6hrs later, with an open tranny case, this thing kept the heat...)
30-60min, unbolting pan, draining fluid(longest part), removing valve body and plate
30min to drill holes, took my time to make sure i did it right
30min trying to pull out the 2nd clutch accumiulator, failed miserably, called it a day
30-40min to put the plate on the valve body, put the valve body back, filter install, gasket and pan and fill the case back with a fresh 9qts of fluid...prolly closer to 8.
and then another like 30min reading instructions, and figuring out where things go, and taking quick breaks...it took from about 1:30-5:30 to get as far as i did..or didnt,lol.
Old Jan 24, 2007 | 12:32 AM
v6stang07's Avatar
v6stang07
cool, not as bad as some say then, let us know if it was worth the saved money
creeper
Apr 27, 2006 09:17 AM
driver187
Apr 19, 2006 03:02 PM
ToplessGT
Apr 7, 2006 06:19 PM
ToplessGT
Apr 7, 2006 01:54 AM
wildazme
25
Mar 6, 2006 01:41 AM
