force pro
Old Jul 22, 2008 | 07:30 PM
troy81's Avatar
troy81
Default force pro
i guess the search is broken... which force pro muffler do i need?
http://store.summitracing.com/egnsea...115+4294791975
Old Jul 22, 2008 | 07:32 PM
troy81's Avatar
troy81
Default RE: force pro
im ordering tonight if i get an answer
Old Jul 22, 2008 | 07:37 PM
fordforlife0225's Avatar
fordforlife0225
what set up are you doing or are you just replacing your single stock muffler
Old Jul 22, 2008 | 08:04 PM
my94pony's Avatar
my94pony
i hope your going duals
Old Jul 22, 2008 | 08:37 PM
troy81's Avatar
troy81
duals...... its bed time
true duals, mach o/r H pipe mach axel overs and tips.
Old Jul 22, 2008 | 09:09 PM
troy81's Avatar
troy81
o and what is a good way to check my manifold for an exhaust leak/crack/blown gasket?
Old Jul 22, 2008 | 09:20 PM
troy81's Avatar
troy81
well i found an old thread on 3.8 it said offset offset so i ordered 5202's. i guess they used to be 5201's but theyre both offset in offset out. i hopw i was right.... lemmi know, maybe i can contact them in time
Old Jul 22, 2008 | 10:31 PM
mustangman02232's Avatar
mustangman02232
what kind of cat back are you using or just having a shop make one?
Old Jul 23, 2008 | 07:00 AM
troy81's Avatar
troy81
ORIGINAL: troy81
hmmmm
Old Jul 23, 2008 | 07:29 AM
The Yellow Pinto
Guest
Posts: n/a
you should be good, man. the exhaust shop will be able to check for manifold leaks and what not when they do the install.
mapitts
May 11, 2016 10:14 AM
jerrytubes
Oct 23, 2015 12:11 PM
JDWalton
Sep 24, 2015 08:47 PM
jstrothe
Sep 24, 2015 12:17 PM
ccdguy
Sep 19, 2015 05:20 PM
