GT light switch
RE: GT light switch
install the ss harnes just like it says. the only dif is you dont use the supplied switch or drill the hole. cut the yellow wire loose and hook it up to the orange lite green it is the actual fog wire for the gt . its a ground thats what the relay needs. i just got thru helping 02pnygt thru this and he said it works great. i also showed him how to hook up an additional relay so that the fogs go off when the high beams are on.
also go here
http://www.2005stang.com/viewtopic.php?t=2410
also go here
RE: GT light switch
ORIGINAL: afixer
also go here
also go here
Yep, this was very easy. Splice the yellow wire to the orange/green just like Afixer said and the fogs will work with the parking and headlights, they just won't shut off with the brights. I added the relay to hook up the shut off with the brights thanks to afixer's help and it was very easy. If you do the extra relay it says to hook up to the wire for the brights. I spliced into the harness coming right off the drivers side headlight, i believe the wire for the brights was a purple one if i remember correctly.
RE: GT light switch
hmm, i just took my test lite to the back of the socket for the headlight. Checked the wires with the low beams on to find which one wasn't hot and then turned on the brights and checked again to make sure and then spliced to that wire. I will have to run outside and pop the hood to look.
TfcCDR
09-14-2015 12:08 PM
