Idle surge after warm start up
Old 08-23-2007, 03:42 AM
BlueDemon
BlueDemon's Avatar
Default RE: Idle surge after warm start up
Joel5.0-I tested theKOEO and I got one code;34 and my Haynes book says "EVP voltage above closed unit" What exactly does that mean? On my continuos memory it gives me code 85; "canister purge circuit'" I'm pretty sure I know what that means because I don't have that purge sensor even hooked up any more. I'll check the KOER codes on Friday but is there any thing you can tell me about code 34? Thanxs againfor the excellent advise on getting that checked out
BlueDemon is offline
Old 08-23-2007, 07:22 AM
Joel5.0
Joel5.0's Avatar
34 - EGR Valve Position Voltage Above Closed Limit of 0.67 volts (O,R)
It means the EVP sensor is reading too high in the EGR closed position. It could be caused by either the EGR valve having some carbon residue causing it not to close all the way down (closed position too high), or a bad EVP sensor. You could try by removing and cleaning the EGR valve pintle/seat area and check if voltage goes below .67 vdc....if it doesn't, the EVP sensor is at fault.
Code 34 will cause the system to delete the EGR function, and provided the valve is not staying partially open mechanically, should not cause any driveability problems. LUK
Joel5.0 is offline
Old 07-27-2010, 10:20 PM
mistab
mistab's Avatar
sorry to bump and old thread, but did you fix this problem? I am having the same EXACT problem right now. Same KOEO code. Let me know man
mistab is offline
Old 05-23-2019, 11:29 AM
Black92gt
Black92gt's Avatar
Default Idle surge after warm
Originally Posted by BlueDemon
Thanxs for the help Joel 5.0 I'll try the code reader on Friday(my day off) Also thankyou,2kwik,for your advise too but like I said before all that stuff is not even a month old so I would think I wouldn't have to clean it,right?
Did you ever get your problem fixed? And what was it? I have a 92 gt and it's maf , and it's doin the same exact thing. Thanks in advance if you get this
Black92gt is offline
Old 05-23-2019, 08:06 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
it would be better if you started your own thread there black92
TrimDrip is offline
Old 05-23-2019, 09:09 PM
Black92gt
Black92gt's Avatar
Default Warm start idle surge
Thanks trim, I'll do that. I'm new to this forum stuff
steve r
12-27-2008 08:35 PM
89mustangfive0
05-14-2008 10:56 PM
Ninety5five0
10-11-2007 01:22 PM
bigopimp
05-16-2005 11:00 PM
MustangsEatSi
03-13-2004 10:33 PM
Quick Reply: Idle surge after warm start up
