Fuel pressure problems
Old 11-30-2010, 06:14 PM
87slow50
87slow50's Avatar
Question Fuel pressure problems
With the key on and pump primed is my pressure gauge suposed to be at zero or should I have pressure? I installed a pro products fuel rail kit 6 months ago. When i start the car theres no pressure and it takes awhile crancking it to build pressure and start.
87slow50 is offline
Old 11-30-2010, 06:59 PM
Bubba 95SN
Bubba 95SN's Avatar
Cycle the key several times, then the pressure should be up. Will run soon as you turn key again. Seems the fuel is not staying in lines. Bleeding off, replace pump. Of course you can keep on driving and cycling switch several times before start.
Bubba 95SN is offline
Old 12-01-2010, 04:17 PM
87slow50
87slow50's Avatar
I changed the pump about a month ago no change. Could it be a bad regulator
87slow50 is offline
Old 12-01-2010, 07:15 PM
Bubba 95SN
Bubba 95SN's Avatar
Pull vacum hose off...does fuel come out?(Bad diaphram) Get a Pro Products for $65 it's adjustable.
Old 12-03-2010, 11:04 AM
alexyikes00
alexyikes00's Avatar
I had the same problem, low fuel pressure I installed a fuel pressure regulator from kirban. and installed a fuel pressure gauge on the fuel rail.. just to find out the little S hose on the pump assembly had a tear..also the fuel pump relay was bad.... but that was my problem...
and yes there should be fuel pressure when you prime the system..
alexyikes00 is offline
Tivo304
08-28-2023 12:19 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: Fuel pressure problems
