what temp thermostat?
http://cgi.ebay.com/ebaymotors/Steel...99607646QQrdZ1
these are just slip over covers but you may like
"back on topic" just trying to help a fellow 98 gt, thanks for the hate DOUCHE(kylebgt)
drain out below the top hose be careful with the twist off spout they can break if you don't know what your doing, when you take off the thermo, antifreeze will slowly dribble out of the manifold put cloths around before you do and also so get the new one in asap and make sure it is in the right spot when you put it back in so the coolant hits it right (open spot parallel with the hose. Tighten back up to 17-19 ft/lbs..add coolant until at the cold mark..Dan
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
