stater bolt question
ok so im finally finished with the transmission, its all back in bolted ready to go, my last thing to do is the starter, its already bolted on but when i went to remove the starter when i pulled the trans i accidentatly broke the 3 stud, the small on above the two big one, is this a problem? idk what connected to it, i only see two wires to go to the starter, a solid red and a red/white one if i remember correctly, if anyone can help me and lmk what wire goes where and what the small stud did? thanks, im hoping i don't have to get a new starter solenoid bc i broke the damn stud!
If you are referring to this stud:
Then it is the +12V switched connection for the starter solenoid. It is where the white/pink wire connects, the starter becomes a small boat anchor without it...
maestro1024
09-21-2015 02:40 PM
