explorer heads?
Old 01-25-2008, 09:42 PM
URLACHER54
URLACHER54's Avatar
Default explorer heads?
if i get a set of the GT40s from and explorer is there any way i can still use my BBK shorties or what headers can i get that will work?
URLACHER54 is offline
Old 01-25-2008, 09:44 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: explorer heads?
get a set of conversion headers..so it'll allow for spark plug clearance
mjr46 is offline
Old 01-25-2008, 11:05 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
if they are regular gt40s not the gt40p you can use the stock headers/ or you bbks
rmodel65 is offline
Old 01-26-2008, 01:11 AM
Bad Karma
Bad Karma's Avatar
ORIGINAL: rmodel65
+1
I've got P's on my car with BBK's as well. Just don't try and use the convert mounts as it will drop the engine about half an inch and run into steering clearance problems..
-Ivan
Bad Karma is offline
Old 01-26-2008, 02:17 PM
URLACHER54
URLACHER54's Avatar
just got the heads and found out they are not the GT40Ps but the GT40s so they will match up with my BBKs so thats cool, got them for $200 and they were rebuild 2 years ago but the springs have to high of a lift so i need to have the springs changed, or should i have them rebuilt, and whats a good spring to still keep the stock valve covers.
Old 01-26-2008, 04:52 PM
mjr46
mjr46's Avatar
springs do not dertermine the valve cover clearance roller rockers will but an extra thick gasket or baffle clearance will fix that if using roller rockers and match springs to cam
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: explorer heads?
