abs sensor. Please help before I cut it.
I'm doing a gear swap in my 94' gt. I found out that you have to break the abs sensors in the back to get them out. Which I did. I bought new ones. Now my question is how do I get to the plug to plug the new one in. If you trace the old abs sensor wire it goes into a rubber grommet and into the inside of the car. I pulled out the grommet and I can not reach the plug to unplug the old one to plug the new one in. I tried to pull on the wire and there is no slack to get to the plug. Is the only way to get to this plug by tearing out the back seat? I dont want to do that. I was thinking about cutting the old wire and cutting the new plug and splicing them together since I cant get to the plug to unplug it. UNless you guys have a easie solution or maybe I'm missing something. Thanks
take what you have to out of the car/inside it to get to it, do not cut and splice the wire!!!!!!!!!!! why?? an abs sensor generates an AC signal and is often shielded by the casing of the harness to keep unwanted RF interference out from interfering with the AC signal that is generated, so do not cut it!! don't be lazy!!!!!!! it'll cost you more in the long run if you take the lazy mans path
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
