Will AFR 185's fit on a stock bottom end???
I have heard about the old afr heads having trouble with the aluminum. I can't remember where I read that since it was so long ago. Anyways, I would thing that if that is true, it just fell out. The rest may be soon to follow if that is true as well.
HERES A LINK WITH PICS AT THE END...WILL NOT LET ME POST PICS HERE:
http://www.allfordmustangs.com/forum...ottom-end.html
they can be fix I have seen heads much worst then that fixed if done by someone that knows what they are doing looks like you will need both valves and some seat work also and the CC chamber will need sized. They are also old heads they have the cross over for the cooling.
Thats what im begining to lean at. Its just that I found them for $350 with upgraded springs, push rods and valves but one needs a new valve seat redone and a sparkplug hole helicoiled. But if its too much head for a stock bottom then I will definitly not consider them at all...
I really do appreciate all the info/help but Im going with my gut on this one. I will pass on them as money is tight and really want something ready to bolt on. I will keep my eyes pealed for some tws...Thanks again.
