1971 Power Steering Pump
Hello Team; Have a new pump and had a basic question. When replacing the pump and installing into the can how far should it go? I have a new one and it came with 2 gaskets? I matched it to the other pump so hopefully that will work. The other issue is as above. I have it tapped into the can with the gasket just inside the lip and it appears to be as far as it can go. The bolt shaft in the rear seems to be seated with the nut drawn up. Sound right?
