Transmission question
Old Feb 13, 2006 | 07:17 PM
cordoba@California's Avatar
cordoba@California
Default RE: Transmission question
what happens if you put too much OIL in the engine?
Old Feb 13, 2006 | 07:24 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: tylerdru
Well, there was fluid in the dipstick so should i just let a little out any ways?
What do you mean that there was fluid "in" the dipstick? Did the dipstick register full after you ran it around the block? Or, did it register over filled?
Old Feb 13, 2006 | 08:19 PM
tylerdru's Avatar
tylerdru
It registered oh **** it is 6 inches in the dipstick.
Old Feb 13, 2006 | 08:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
OK, let's start again. 5 1/2 quarts of fluid is the capacity for a C4 automatic transmission. Assuming you drained it all out, then 5 1/2 quarts should have gone back in. However, the only way you can check the fluid level in an automatic transmission is to get it hot before checking. Now, did you take the car out and drive it until the fluid got hot? If not, you need to do that.
Old Feb 13, 2006 | 08:31 PM
tylerdru's Avatar
tylerdru
5.5 quarts probably didnt go out. I just took the pan out and it dripped over night so maybe like 4 quarts drained out. I will take it for a ride tomorrow.... Open headers lol
Old Feb 13, 2006 | 11:16 PM
6mustang6's Avatar
6mustang6
I love open headers. If you put too much oil in the engine, It will foam up, called Oil Foaming. It loses it's viscasity, and will burn up, the engine..... it's likely anyway.
Old Feb 14, 2006 | 12:13 AM
Silver Ponys's Avatar
Silver Ponys
Is your speedodmeter cable on the driver side maybe the oil ran out there
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
04stangman
Sep 17, 2015 01:45 PM
LivingInThePast
Sep 16, 2015 12:20 PM
vintageaion
Sep 8, 2015 10:45 AM
