Reverse Valve Bodys
Old Feb 5, 2009 | 03:05 PM
Roushstang07's Avatar
Roushstang07
Default Reverse Valve Bodys
Anyone have one of these, whats the pros and cons of having one, faster shifts etc. would it work well with a T56 tranny. with a Twin Disc Clutch. I am thinking of putting one in a Fox Body, I wanna eventually get a 5.0 LX Fox and want to make at least 5-600 hp if not more. if the motor is shot I may try to rebuild it if not ill throw a BOSS 302 in there or something, but i mainly wanna know what the values of having a reverse valve body are.
Old Feb 5, 2009 | 07:30 PM
Roushstang07
no one know's???
Old Feb 5, 2009 | 11:58 PM
Roushstang07
bump... I guess I could delete my post then.
Old Feb 6, 2009 | 12:28 AM
Jfsram's Avatar
Jfsram
First thing you need if you want a reverse manual valve body is an automatic transmission.
Old Feb 6, 2009 | 06:17 AM
GreyStang's Avatar
GreyStang
lolol
Old Feb 6, 2009 | 08:44 AM
Roushstang07
oh so you can't use a manual tranny with these.
Old Feb 6, 2009 | 12:45 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
No, you cannot, they are for autos only.
Old Feb 6, 2009 | 12:50 PM
Roushstang07
so is it like having a Clutchless manual transmission or no.
Old Feb 7, 2009 | 10:18 AM
Jfsram's Avatar
Jfsram
I can best describe it as an automatic that NEEDS to be told what gear to be in.
If you leave the shifter in 3rd. Stop the car, you'll be taking off in third.
The biggest reason I don't like to refer to them as a clutchless manual is because it still has a torque convertor. So it's pretty much the same transmission but does not shift on it's own. The reverse is refering to the forward gears. Originally it's P, R, N, D and the lower gears, like 2 and 1.
On a reverse manual valve body your shifter will now be P, R, N, 1, 2 and 3.
svfetter
Oct 5, 2015 11:39 AM
2poor4u2
Sep 26, 2015 11:08 AM
lmurf60
Sep 24, 2015 10:07 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
LivingInThePast
Sep 16, 2015 12:20 PM
