HEET
Old Sep 29, 2008 | 12:55 PM
Riptide's Avatar
Riptide
Default HEET
Is this product safe to use with our engines and any aftermarket tunes we might have loaded?
http://www.goldeagle.com/heet/products.htm
Old Sep 29, 2008 | 06:45 PM
Goldenpony's Avatar
Goldenpony
Default Heet
I believe Heet is nothing more than alcohol. Alcohol absorbs water in the fuel system and carries it into the combustion chamber where it is burned along with the gasoline. If you use it per the directions, it is probably safe to use in our engines.
Old Sep 30, 2008 | 10:39 AM
157dB's Avatar
157dB
Cut & Paste Expert
Its pure alcohol.
It effects octane levels.
Old Sep 30, 2008 | 11:02 AM
Riptide's Avatar
Riptide
Increases octane levels I'm assuming? Maybe I need to read more about this stuff. I've been told it's a good idea to put one bottle of this stuff through your car every winter once it starts getting real cold out.
Old Sep 30, 2008 | 04:49 PM
157dB's Avatar
157dB
Cut & Paste Expert
It lowers the octane rating. Thats why E85
does not get as good gas milage as petrol.
SeaFoam is better and does the same thing
without the corrosive side effects of the Alcohol.
I run a can thru the fuel system every 7K or so miles.
Old Sep 30, 2008 | 08:06 PM
Nuke's Avatar
Nuke
I wouldn't use it unless you suspect you have a problem. If you drive frequently AND keep your tank as full as is reasonable I wouldn't worry about it. If you're storing your car, keep the tank full and don't worry about it.
You don't take aspirin just in case you might get a headache, do you?
Old Sep 30, 2008 | 08:27 PM
Riptide's Avatar
Riptide
How can you tell if you have water in the gasoline?
Old Sep 30, 2008 | 08:37 PM
Goldenpony's Avatar
Goldenpony
Default Heet
FYI, alcohol actually raises octane, not lowers it. The reason E85 gets lower mileage is alcohol has less energy per pound than gasoline.
Old Oct 1, 2008 | 08:56 AM
157dB's Avatar
157dB
Cut & Paste Expert
Yea, I did some extensive research after posting and found that to be true.
STA-BIL®
Mar 21, 2016 10:47 AM
vabear
Jul 30, 2010 10:17 AM
RojoDojo
Apr 30, 2008 11:30 PM
cookiemonster
Nov 30, 2007 06:01 PM
cookiemonster
Jan 7, 2007 08:56 PM
