Horn Issues PLEASE HELP!!!
Old 05-12-2010, 06:07 PM
byeofficer07
byeofficer07's Avatar
Default Horn Issues PLEASE HELP!!!
Hey and thanks in advance for any help anyone can give. Have a 2007 Mustang GT, was driving down the road and the horn just started going off. If you turn the key off and back on it will not go off.....untill you start the engine. It will not honk if key in run, but if you start the engine it does. So to not get shot I unplugged the horn. A week later was changing the grill and plugged it back in, now no horn at all either from the alarm or the column.... All fuses and realys are good
byeofficer07 is offline
Old 05-14-2010, 12:46 AM
shadow052001
shadow052001's Avatar
Default Horn issue
I have a 2006 Mustang GT and I was having the same problem for about 6 months. I took my car to two different dealers to find out what the problem was. When my car was being put together a the Ford factory someone dropped an extra screw in the horn area which cut into the wires and cause a short. They pulled the screw out and it never happened again. I
shadow052001 is offline
Old 05-15-2010, 04:02 PM
157dB
Cut & Paste Expert
157dB's Avatar
Check for pass side wet carpet/pad from the water leak syndrome.
Disconnect the horn wire from the back of the SJB and see if the
problem persists. If not, its the horn button or wire to the SJB.
If it still honks with the horn button wire disconnected from the SJB,
its the SJB that is triggering the Horn Relay in the BEC under the hood.
Wet SJB causes all sorts of problems and its a known issue.
157dB is offline
Old 11-01-2022, 12:24 PM
kdphoto
kdphoto's Avatar
My SJB has gotten wet several times till I figured out to clean the rubber grommets. So if it is the SJB can you just go around it with a wire direct to the horn?
kdphoto is offline
Old 11-09-2022, 09:45 PM
royjj12
royjj12's Avatar
Youtube.com has videos on how to wire horns.
royjj12 is offline
Cargon
07-13-2007 04:30 PM
grn94gt
10-15-2006 06:05 PM
Britinastang
04-06-2006 11:58 PM
carraig042
07-24-2005 01:26 PM
vizion
04-29-2005 06:28 PM
Quick Reply: Horn Issues PLEASE HELP!!!
