Clutch master cyl. reservoir ?
Hello,
Looking around under the hood of my '08 GT, and I don't see a fluid reservoir for the clutch ?? I'm pretty sure these cars have a hydraulic clutch system, so what gives? Please excuse my dumb....
thx,
-Ken
thx,
-Ken
Ok, well I guess that makes since, since the brakes and clutch use the same type fluid- why not have one res. for both. I just didn't think of that or expect it 'cause all the rest of cars I've had they were separate (and the clutch fluid always seemed to turn blacker, quicker. Which makes me wonder how the clutch fluid will affect the brake fluid sharing the same reservoir....hmm
If you look at the brake reservoir, from the front of the car; the bottom rear of the
reservoir has the slave connected to it. Mine has the tube that comes off the
back, and the barb is there for the push on connector, but the plastic after the barb
is pinch welded shut. I was thinking of opening it up to release the brake fluid so
I can flush it, cap it off, refill then bleed.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
