3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Leaking coolant
Old 02-14-2019, 07:40 PM
Sasquatch76522
Sasquatch76522's Avatar
Default Leaking coolant
Hi this is my first post also my first ford and haven't had to work on it until now. My car is leaking coolant I checked the obvious culprit the water pump and thermostat housing and it's dry. The area it's leaking from is from behind the front cover on the passenger side. My question is why would it leak from there and how screwed am I? It has simple mods intake exhaust ghost cam tune and the coolant reservoir has never been opened as I am the first owner of the car and I've never opened it year is 2014
Sasquatch76522 is offline
Old 02-15-2019, 12:54 PM
Fluids always flow downward so, just because it looks like it's coming from behind something doesn't mean it originated from there. I'm not at all familiar with the 3.7L engines so I can't even begin to guess.
What is above and slightly left or right of area where you see the leak coming from that contains coolant? (hoses, pipes, etc)?
Old 02-15-2019, 08:00 PM
Sasquatch76522
Old 10-04-2020, 11:55 PM
RoadtripMustang
RoadtripMustang's Avatar
Hi, were you able to figure out what the issue was? Mine has developed a similar leak, and it looks like it is coming from the same place.
RoadtripMustang is offline
Old 10-30-2020, 03:05 PM
Choppertwo
Choppertwo's Avatar
check your coolant level first
Choppertwo is offline
LandonWiseley
04-08-2016 01:34 PM
Greg950
08-04-2014 01:24 PM
SmallFeesh
12-04-2009 08:45 AM
97gtmt
13
07-11-2007 03:46 PM
FredTT
04-13-2007 08:34 PM
Quick Reply: Leaking coolant
