curious
ORIGINAL: Lee Willis
Another popular conversion is a Ford 302 into a Miata, and there isn't THAT much weight added despite the doubling of the HP, and some of that weight is due to a much heavier transmission that you need along with the engine.
http://www.fergfab.com/gallery/LS1-V8-miata-conversion
__
and matt keep posting it's funny
ORIGINAL: 66chevyIISS
How about a LS1 Miata??
__
__
Guest
Posts: n/a
ORIGINAL: THUMPIN455
There is also alot of V8's with little more than headers, stall, and underdrive pullies turning 11's on DR's, some are still getting 28-30 mpg highway too. Right around $1500 in mods, so whats your point?
Maybe its not so much underestimates as much as it is dont care because they are still behind us. So what if they can get in the 11's, in the bracket car world that is a grocery getter. 11's can be run with a V8 with stock parts, even in 4000lb cars. Case in point:
http://www.pontiacstreetperformance....ld455jh99.html
He was running 12.4's with stock heads, stock RA IV cam, stock intake and a stock Quadrajet carb before he built this engine. I know so what right? Its not a Honda so it sucks. 11's are easy to get, first car I got there with only had $2700 in the engine and $5k in the entire car. It was still streetable and made a 100mile round trip no problem on quite a few occasions. Was driven to the track, raced, and driven home. So what, thousands of cars are faster and you can pull up as many as you like that run a certain number.
ORIGINAL: 2000Si
Not every car needs boost to be fast.
There's quite a few B series DOHC swapped EG (92-95) Civic hatches on Honda-tech running 11s NA.
Full bolt ons, engine swap, suspension, tires. They'll cross the line well within the 11 second mark quite easily. Everyone simply underestimates a car here. That's how.
Wait wait... I know what you're going to say "buy a fox and throw 500 at a nitrous kit! yay... no, that's not my point. Don't even bother.
Thanks for completely ignoring my entire point to show me inane pictures and ramblings about V8s. We already know.
in theory more revs means there are more power strokes per minute, meaning more hp. torque is when your engine is most efficient. any serious racer or anyone who actually works on engines should know this. of course, there are limits, like my car kept pulling until 5250 rpms on the engine dyno, but i don't know how much more power it pulled
A b16 may only make 111 ft lbs at the crank, but with 160 hp backing it up, it's using that 111 ft lbs more efficiently than say a D16 which might make 127 hp and 111 ft lbs. That's where the efficiency comes from. How many four bangers have any of you ever owned that made 29 mpg highway at 74 mph while taching 4000+ rpm for the entire trip? There's your efficiency.
The 03/04 Cobra engine has forged internals and additional bolts on the mains, we are not talking the same thing as stock GT internals with cast crank, 2 bolt mains, cast rods with weak rod bolts. The Cobra engine already has the stuff you need to buy for your GT motor to handle serious HP.
ORIGINAL: pj1010
That seems contraditory to some things I've heard. 1000 horse on stock internals?
ORIGINAL: angcobra
Boost is the answer, in theory, each 15# of boost doubles HP.
Also keep in mind "stock" internals for some cars are forged and the 4 cylinder block is strong.
The limitation on "stock" internals for mustang is because Ford chose to use cheaper parts. The "stock" 03 Cobra has forged internals and should be okay to make near 1000 HP.
Guest
Posts: n/a
ORIGINAL: angcobra
Atmospheric pressure is 14.7 psi. adding another 14.7 psi to your engine won't exactly double hp... but it will be one hell of a kick in the pants the first time you floor it.
****ing reality always intrudes. if you could get another 14.7 psi of boost without any additional loss, you'd double HP. I don't think anybody said the reason theory is not reality. usually, that's an important point.
Reading this I wonder how many actually know the difference between Hp and torque. Did you ever notice on a dyno graph that the Torque and HP cross at 5252 RPM? The reason for this is the dyno measures torque output and HP is just a calculation from the torque. HP = torque X engine RPM/5252. 1 HP = 550 ft-lbs per second.
So yes, if you build/tune an engine to produce torque at higher RPM you will have high HP output. Likewise if you build/tune an engine to have low end torque, you will have lower HP output. 1 simple way to shift the torque curve is with cam timing, advancing the cam timing will typically move the torque curve to lower RPMs.
4 cylinders, especially Jap engines are built to produce the torque at higher RPM (variable cam timing helps shift the torque curve) and allow the engine to turn higher RPMs, this will pump the HP numbers up. V8s are typically setup for low end torque and not so high RPM thats why they will have lower peak HP.
The real power that does the work is torque, the key is to match the gearing and weight to match where the peak torque is being made.
I agree reality is not theory. The reason I put it that way is because different modes of boost have different efficiencies. You eat up some of the increase power by the power it takes to make the boost and you loose some due to heat put into the intake air due to being compressed. Some methods use more power to create the boost and some methods add more heat.
ORIGINAL: 2000Si
In theory yes, but not in reality.
ORIGINAL: angcobra
daltron
Apr 28, 2016 08:10 PM
mungodrums
Oct 7, 2015 04:01 AM
movielover40
Sep 10, 2015 03:34 PM
