Compound Boost Setup
Actually it's posted up to give others info. I could honestly care less what someone on the other side of a keyboard has to say about a setup they know nothing about.
This is also why most people who know what they're talking about steer away from mustangforums.
Too many haters and ignorant people.
And AGAIN, you gave NO dyno numbers/sheets to back up ANYTHING that you said. Hell, even your "Track" video lacks any numbers. I can only think of one reason why you keep withholding that info...
7.412@104.1 /w 1.862 60' Working on the launch and really just getting a feel for the track.
Had a lot of issues spinning in 2nd and launching even with the tires in my sig in the teens.
Was fun and I learned a lot about the setup on the track which is way different then it handles on the street.
I'm confident now when I get some practice and a 2-step I'll be able to make some nice passes on a good 1/4 track.
After the car gets re-tuned that is, that was the last outing on this tune so it wont really be comparable when I got out again which kinda sucks.
Should put me at around 800 if it keeps building power per psi like it was previously when we went from 14-16.
We'll just be starting to get into the turbos band a little at 13-15 turbo psi. The electronic boost controller should help stabalise the boost a lot better then the mechanical one I had. Atleast that's the plan.
That would be correct. At 16 #s it made right between 575-600 after correction. Today I got the exhaust fixed up, we are hoping that helps it out a little with power and then with the meth kit I'm going to go for ~21-23psi on the street.
