Whipple ordered!
Old Apr 13, 2010 | 09:16 PM
  #131
candymanjl's Avatar
candymanjl
Originally Posted by Vectorpat
Dual AeroForce FTW!!!
no doubt! one day I'll get some time and install the wideband kit for my Aeroforce's, just gotta weld the bung
Old Apr 13, 2010 | 09:18 PM
  #132
candymanjl's Avatar
candymanjl
Originally Posted by 2007CalSpec
Thanks guys! I still need to add coolant, s/c oil and bleed the system. I was going to install a fuel riser block for the fuel pressure gauge but one of the bolts snapped. I didn't even torque it that hard. Cheap bolt! Guess I won't be installing the fuel pressure gauge yet. Another thing is that it doesn't look like it's going to fit with the intake tube being so close to the fuel pressure sender. How did you guys get a fuel riser block to fit under there?
I'm going to start installing the A/F and boost gauge now. After that I'll add the coolant, etc..
getting excited for you man! just double check everything before you go on a test drive, and have fun
Old Apr 13, 2010 | 10:50 PM
  #133
2007CalSpec's Avatar
2007CalSpec
Originally Posted by BruceH
Yes. It's premeasured. The sight glass will be above halfway but will come down when the motor is running.
After I asked about the oil, I went back out and poured some more oil and started to see it flow towards the sight glass. The entire bottle is definitely premeasured like you said.
Originally Posted by hammeron
i bucked the trend and went maverick on that one. after looking at all
the possibilities i ended up placing a fuel pressure sender in the fuel
line that runs between the rails. pic is available upon request, but it
gets installed on the passenger side near the rail.
now that the aeroforce is available, i think most just rely on that
for fuel pressure readings.
I'd love to see a picture of your fuel pressure sender. Thanks!
I couldn't finish the build today. Got tied up trying to run the gauge wires down the dash vents by the windshield. What a PITA! Running a Cobalt A/F harness down there is impossible. Started cussin and moanin and decided to quit for the day. lol
Old Apr 13, 2010 | 11:02 PM
  #134
candymanjl's Avatar
candymanjl
ha ha, yeah, that's a good point to stop on my build I hit a point real late one night where I was about to start some wiring stuff. I blankly stared at the directions for like 5 minutes straight so I figured that was a good place to stop before I FUBAR'd something
Old Apr 13, 2010 | 11:20 PM
  #135
2007CalSpec
lol So you know I felt then. I think it would've been easier if I had gotten a stereo area gauge panel; that way I wouldn't have to mess with running wires down the defrost vents.
Old Apr 13, 2010 | 11:28 PM
  #136
candymanjl's Avatar
candymanjl
finding a route to the center of the dash looked annoying, that's why I went with the A piller, nice and easy
Old Apr 14, 2010 | 07:33 AM
  #137
liberty911's Avatar
liberty911
Here's some pics...
I see you decided against relocating the IAT sensor.
The SC oil provided to me by Whipple was way more than was needed. Don't assume Whipple provides a pre-measured amount. Its up to the installer to perform a proper assembly.
Looks good so far!
Old Apr 14, 2010 | 09:05 AM
  #138
hammeron's Avatar
hammeron
ok here it is... you have to either really want an old fashioned analog
fuel gauge, or don't yet have an aeroforce, to go through the
added trouble, but I like having it...
the wires have since been cleaned up (old pic).
Old Apr 14, 2010 | 10:28 AM
  #139
2007CalSpec
Looks good so far!
I actually bought the 3/8" NPT tap and 9/16" drill bit for the relocation but the guy at NAPA gave me a tap handle that won't fit the tap. I didn't want to waste anymore time by running out and finding the right handle so I figured I'll just use the 1/8"NPT already on the passenger side for future relocation.
Thanks! I'll go find one like that. The ends are 3/8", correct?
Old Apr 14, 2010 | 10:49 AM
  #140
Riptide's Avatar
Riptide
I'm assuming that if you are planning on using the whipple tune relocating the IAT is not necessary?
