View Full Version : 6 Cyl (V6) Applications
  1. Rear Caliper Bracket
  2. Rear bumper installation?
  3. question.
  4. 3.8 pinging under light load
  5. 1998 3.8 drop top
  6. beating the tuners on a budget
  7. V6 vs V6
  8. Stock 99 V6 poor performance???
  9. Hello :D
  10. Blown Head Gasket
  11. Windstar Kit or Tuner?
  12. Shocks and Struts
  13. 3.8 Liter Cold Air Intake concern
  14. Lower Grill headlights
  15. Lowerin 96 Stang..Questions
  16. tire size help- meat!!
  17. super coupe to 95 mustang swap
  18. Need Help! Random Beeping!
  19. New rear end
  20. HELP WITH MUSTANG CODES!!!
  21. Boggin out
  22. Going boosted!!! Needing help
  23. Cool Can anyone help me?
  24. Never ending exhaust leak P.II
  25. 95 auto v6 mustang tranny help!!
  26. Lowering
  27. Problem with the speedometer..?
  28. Yokohama or Falken???
  29. I have a 2002 engine
  30. question
  31. split port swap tune
  32. Sputtering problem?
  33. 04 base model upgrades
  34. 98 front bumer options?
  35. This Shop V6 Stupid?
  36. Proper way to clean air filter
  37. 1999 mustang V6 Cats questions
  38. pro charger question....
  39. Guys, I need some experts
  40. Misc. Engine Block Questions
  41. getting a sN95
  42. emblems
  43. 18 x 9 Cobra wheels TIRES?
  44. GT MAF ON A SIXXER?
  45. Whats better long or shorty headers
  46. Dual Exhaust and Rear Bumper 08 V6
  47. ok guise
  48. hmm
  49. Muffler Question.
  50. what auto trans came in v6
  51. 98 V6 losing power. HELP PLEASE
  52. Loaded Cylinder
  53. Misfire
  54. Inspection Problems?
  55. Stuck Rpms Help
  56. ? Going With a Dual Exhaust
  57. shifters
  58. could a cai hurt ur car
  59. Very poor mpg, Bottoming out, & Tranny
  60. BBK 65mm Throttle body..
  61. Changing fuel filter
  62. T+Lock & Gears
  63. Oil Pressure Gauge - Mechanical or Electrical??
  64. Why is my 97 so slow?
  65. My Oil Gauge...
  66. My Sons Mustang Got Wrecked
  67. I've got the Squeaks
  68. steeda tri ax shifter
  69. Banjo Bolt
  70. Engine missing at higher speed.
  71. After market headlites
  72. diablo predator
  73. Brakes and Rotors
  74. Can't fill with gas
  75. v6 throtle problems???
  76. locking lugs nuts
  77. Does anyone with a 3.9L (2004) have this CAI?
  78. What are these wheels?
  79. cherry bomb exhaust??
  80. for those with LT need advice
  81. GT Starfish
  82. My 95 Mustang wont fire???HELP PLEASE!
  83. Went to test fit hood... couple of questions
  84. Finally got pics of the GR40 setup
  85. Anyone running aftermarket taillights?
  86. transmission fluid/clutch issue
  87. 2001 V6 hard to start when cold
  88. autometer questions??
  89. Anyone shave sidemarkers??
  90. best online store
  91. what's with the squeek
  92. i think i solved the whole dilemma of starting problems
  93. Picked up the new hood..
  94. Revving engine and just wondering..
  95. who makes these?
  96. is this a Deal or wat
  97. brake chatter
  98. was ticking really bad, now missing really bad
  99. Why does this happen?
  100. New Rear Bumper
  101. Car runs poorly and no check engine light
  102. What Rims?
  103. Heres what us sixxers need, cobra bumper, shaved lettering.
  104. fog light wiring
  105. CAI and turbo question
  106. vibration problem???!! help!!!
  107. Rear Seat Delete
  108. thrush mufflers?
  109. Tryin to convert to a bigger engine
  110. Nitto Weight Capacity
  111. Suspension done.. Just thought id update with some pics..
  112. B&M hammer shifter install
  113. Door lock on 2004
  114. pro charger and motor question
  115. If installing aftermarket gauge do stock ones still work??
  116. tune/emissions issues
  117. rotors and brake pads
  118. What should i buy for my car
  119. best v6 exhaust?
  120. What kind of spoiler?
  121. Need some tips..
  122. how to bleed cooling system.
  123. Stereo installation
  124. How much HP can you get on a 2000-2004 V6?
  125. mac lt's
  126. A few questions...
  127. I think my battery is to small.
  128. Noob question...
  129. spark plug wire diagram
  130. !!!v6 Mustang Under-drive pulley!!!
  131. At a crossroads my fellow 6'ers
  132. transmissions?
  133. !!!02' Mustang V6 cat. questions?!!!
  134. Driveshaft Safety Loop
  135. Some ides for next mods....
  136. Where can I find a fitting for the h-pipe..
  137. cam heads and headers
  138. header flange bolt broken
  139. headlights ??
  140. my car is still broken... $1000 later
  141. 2002 v6 upgrade questions
  142. Severe Coolant Leak
  143. How difficult is it to change insturment colors?
  144. car problem, video included. please help
  145. True or False regarding cats
  146. IAC?
  147. HELP! A/C blows through defrost
  148. 2006 shutting off
  149. high flow cat recommendations?
  150. The never ending exhaust leak....
  151. Straight Six 200 performance options??
  152. How hard would it be to sell a 2004 V6 - Auto?
  153. Some pics of my engine swap
  154. '05 4.0L Supercharger
  155. What tire size do you guys recommend with 18's?
  156. o/d ?
  157. what are the best bang for the buck mods
  158. Ok I got a question about the something and don't know nothing about pipes...
  159. Looking for a 6'er to mod for cheap!
  160. Engine Problems
  161. Thinking of getting a group buy together (Hood Pins)
  162. rear brakes dont work!!!!!!!!!!!!!!
  163. wanting a small "project" car...here are my thoughts
  164. Vacuume lines diagram
  165. Gauges Flicker
  166. Press Gas And Hear A Chirp?
  167. New Car!
  168. 99-04 GT bbk o/r xpipe FIT on a 04 v6
  169. 4r70w rebuild interval?
  170. 10 sec tick at startup
  171. change of mind on mach 460
  172. steeda udp?
  173. Front brakes dragging
  174. What is the difficulty level in having items polished??
  175. i dont know if you guys saw this over in the v8 forums but...
  176. Should I be worried?
  177. check engine light is on... IAC sensor?
  178. 3.8L fuel injector clips
  179. Exhaust question
  180. Synthetic oil
  181. SN 95 owners with head/tail light covers
  182. lug nut
  183. Both Hi beams blew within a week
  184. how to dissect mach 460 body harness to my body harness??
  185. Which Tuner is best for power?
  186. COOLANT LEAK HELP!!
  187. Fog light question- What do I need, and how do I do it?
  188. Need a favor from someone with a stock gt hood with scoop...
  189. Will shaker setup work with the engine upgrade?
  190. Anyone know where i can get or part numbers??
  191. Have a few bucks which would you recommend..
  192. Need Stereo Help!
  193. Changing PCV valve
  194. Should I buy these Cobra wheels?
  195. Help Caliper problem
  196. QUESTION ON 3.9 TURBO, WHIPPLE
  197. What do you guys think..
  198. anyone dealt with torque converter code issues??
  199. gt axle backs?
  200. Wheel Differential?
  201. Lt headers?
  202. 05 Mustang FRPP Exhaust Kit Rattling Problem
  203. conv. top
  204. Driveshaft Issue
  205. turn signal switch
  206. MSD Wires don't fit??
  207. Air/Fuel Ratio Gauge..
  208. Quick question on header plug?
  209. Rough idling..
  210. please help - automatic transmission question?????????
  211. cherry bomb glass pack
  212. anyone done a auto to 5speed swap?
  213. Gears
  214. uppers and lowers
  215. last question on header before i buy
  216. 2000 v6 headlight bracket issue
  217. Instrument Cluster issues
  218. Pacesetter Lts with Egr
  219. Help swaping out a 3.8 for 5.0
  220. X2's are on; should I have gotten bumbsteer too?
  221. Just a quick test..
  222. Flowmaster
  223. Largest wheel size on a 96 V6 coupe
  224. Why are people sellins their V8s?
  225. Transmission Cooler
  226. More Parts
  227. Streering wheel question
  228. My baby is going in for work tomorrow
  229. A couple new pics
  230. What's up with people?
  231. Just wondering if anyone has tried this..
  232. P&P
  233. Top speed with 4.10 gears (Auto, V6)
  234. Do 05-10 Mustang wheels fit 99-04?
  235. anyone have any ideas?
  236. Saleen vs Bullitt Wheels..
  237. Quick Brake Question..
  238. What Chop Do You Guys Like Best?
  239. Just attempted to install the Oxygen Sensor Extentions but no luck..
  240. Tune...
  241. Best oil to use in the 4.3
  242. Quick Question Regarding Tuning..
  243. Cobra Brakes
  244. V6 EXHAUST QUESTION
  245. COBRA BUMPER
  246. anyone installed a Eaton M90 superchrager on tehr 3.8L v6? Need help
  247. 1995 Mustang v6 stumbles hesitates on right hand turn only?
  248. Engine Questions
  249. HELP!! Car problems
  250. used engine question
