- Quick gears question
- 2001 v6 shift light
- V-6 Drive Shafts
- 310 lph fuel pump
- Performance Tuning?
- where is the purge control valve ? P0443
- Replacing exhaust manifolds with headers, need help!
- Tranmission wont stay in gear. (auto)
- Port+polish upper intake
- exhaust tips problem
- how hard would it be?
- header gasket
- Tuning
- split port swap..?
- paint questions/cost
- 98 3.8 V6
- lowering question
- Compucar Nitrous System?
- My car locked me out... POROBLEM IS MUCH WORSE
- AHHHH ! Throttle Body? Intake?
- first car 94-98 mustang
- little seat belt problem
- Tuner Question
- Head Gaskets
- best cai
- Need new Brakes??
- Goin Back To Stock,LOOK INSIDE
- v6 mustang fog lights?
- help!! weird noise
- I don't know if this belongs in the tech section but...
- Roush Springs on, pics...........
- Lowering my car... what do I need
- differentials
- opinions on tubular a-arms? ne1 have them?
- re thought exhaust problem
- WHAT IS GOING ON...???
- So what is a 3.9 really?
- Despondent, Discouraged, Sad
- White face Gauges
- intake HELP!
- is it worth it....
- Is a sct x-calibrator worth it??
- 4 Questions (2 new ones)
- 4.10's + trutrac installation?
- 99-04 gt bumper??
- Used Diablo Tuner question
- new clutch came in today
- wheel question
- Oil Drain Plug...
- 3 core on a 6?
- Rear end noise *UPDATE*
- 94 3.8 problems, see if you guys can help me out
- Does your suspension sound like this?
- Problem with '03's CD Player.
- COBRA TAILIGHTS
- Need to replace ring & pinion gear
- Help me diagnose
- Will a 1995 GT Auto Transmission Bolt up to a V6?
- PA inspection
- need help? check out the web site
- Supercharger with wastegate
- flowmaster orig40 v. super44
- hmmmmmm
- Cosmetic or Power?
- Droping a sub in the v6
- what else is needed
- Mustang Under Drive pulley
- installing midpipe
- I need some tuning help, car shuts down after 3 seconds w/ tune
- New duals on the 97
- dragging w/auto tranny. OD on or off?
- What exhaust??
- Drivetrain?
- Power Seat Issues...any suggestions?
- new guy with 2 simple ?'s
- bumper question
- subframe conectors and other strengthening mods...
- Throttle Body & Spacer Problem
- BBK lowering springs
- Twin Turbo Kit
- oil cooler
- Stupid Question?
- small exhaust problemo
- HELP!!!!!!Auto trans help. Need fast answer
- I need help finding the temp senders on the 2000 3.8L engine.
- Surface rust
- Port and polish gains
- Which is louder?
- Problem with MAC Shorties and Wires
- Tires..
- Towing Capacity - Boat Towing
- Brake Fluid Leak?
- Vinyl for Trunk
- Out of the blue... Do your own work?
- shift light
- transgo shift kit
- Whats that sound?
- Will this System work
- Head'er'z
- Shorty Header ? for those who live in emisson testing counties
- k&n cold air intake
- Will these fit for my car?
- Gears or Swap
- What do you think im running?
- 80 series
- EGR low vacuum flow P0401 code
- Guages
- pic of cracks in piston
- Horse Power Gain
- Which exhaust?
- What you have, what you want, what you want to run??
- Exhaust Tips Help
- Who is stroked arround here?
- Car is making noises
- Just a thought...
- muffler ?
- HELP ME WITH exhaust
- whats the stock hp and torque?
- Loud Exguast
- Shifting to save gas?
- predator tuner question
- gas mileage w/ 4.10's
- a possible problem?
- 6 cyl carb part needed badly!!!
- 84 3.8 questions: knock sens, trouble codes
- Look for wheels need help
- Aluminum Driveshaft??
- double post...delete ****
- flywheel
- rpms stay high during shift
- quick question about tri-ax shifter
- 2001 Mustang Coupe suspension and brake upgrade
- Trunk Latch
- how do i seafoam?
- Inkate ?
- Do I Need This?
- Electric Window Rollup Noise
- spark plugs
- gt bumper
- Transmission type?
- radiator
- NOT STARTING.
- Engine swap
- Finally.. but not..
- Air Filter Thoughts
- What engine model?
- Seafoamed, When's The Oil Change?
- 01' 3.8 firing order
- IM very fickle i know! I hate being me
- Cobra R Spoiler
- 4.2L stroker
- CAI connectors
- AC only Through Defrost
- Cost of Dyno
- 03-04 v6 specs
- engine bay dress up
- 3.8 rear end
- MOVED: Paint questions
- SCT TUNERS
- NEED SUGGESTIONS!!!
- Engine Swap Wreck Tips?
- how will be?
- pipe size??
- Air-Ride
- has anyone ever encountered this?
- Theft System
- O/D Button
- automatic shifter button wont push in?
- high temps
- MOVED: Rims 4 Sale...
- gears work on 07 also?
- Cobra KIT
- please delete
- aight this is pissing me off, any suggestions?
- I need help
- GT Bumper height
- what to get
- mufflers
- 84 3.8 dress-up question
- 3.73 or 4.10 gears?
- will these wheels fit
- H-pipe
- The Next Step....
- Would these rims fit!?
- eaton m90 on split port 3.8
- Any Discounts?
- Turn signals won't work
- A little tip for you 94-98 guys
- metal clicking sound from engine?
- are cobra rear brakes diff size than v6?
- Elevation querry
- Tires cupping
- Mach1 Strut Tower Brace?
- power flux with a/c on
- possy traction
- Clutch cable is too short
- Tuners
- i have a ? about my oil pressure dropping. please help
- Please HELP me!!!!
- metal clicking????
- Forged Internals
- Battery Relocation
- exhaust installation.. please
- question about dual exhaust... looked for input already...
- loud squeak coming from wheel
- Removing Spring Isolators
- where to find a gt take off exhaust???
- Shorty headers?
- fuel filler neck
- Hey all
- Flash Tuners
- 1986 mercury capri.. need your help!!!!
- ppl wit LONG TUBE heads only...
- Do I need anything else?
- How strong is a V6 automatic transmission
- Headlight knob
- 8000 rpm
- Lowering, Cut or Not?
- Would this swap work
- Maybe some help form any turboed sixers...
- New Engine Won't Start
- Fog Lights
- just arrived!
- headers and exhaust
- Supercharge v6?
- A/ condensate
- Coilovers
- Water in the car.
- Helicopter NOISES?? Help!
- 3.8L forged pistons and connecting rods
- Exhaust Tip Hangs To Low Help?
- Brakes and Body Shops
- MY MAC EXHAUST SOUND CLIP!
- GT BUMPER EXHAUST HANGS TOO LOW!!!!!!!!!!!!!!!!!!!!!!!111
- Exhaust + headers installation
- Fog Light Wiring Harness
- HELP!!!!!something is wrong with my car.
- What do I get?
- exhaust tips?
- k member help
- 18in rims mess up calipers?
- startin off new
- gt takeoffs
- milling the heads
- any suggestions?
- New engine in, got some fuel problems.
- Any help i can get.
- Power Steering---- Help
- 03 v6 wheel offset
- 3.8L/3.9L
