View Full Version : 6 Cyl (V6) Applications
  1. m90 tuning fun
  2. Dumped exhaust pros/cons?
  3. WHY wont the starter turn?
  4. i think im gonna tank the m112
  5. Fuel Line part #? (2000 3.8L)
  6. Cold Air Intake Decision
  7. Shifter knob
  8. torque loss
  9. What is the best in-tank replacement fuel pump for a 96'?
  10. Limited Slip Question
  11. engine problem
  12. Anyone know what hood this is..
  13. where did you guys get your hangers?
  14. 4.0 Dual Exhaust
  15. Project: Texas Heat
  16. 1997 rims
  17. IAC remote kit -For those guys with Windstar intakes-
  18. stock mach 1 rear sway bar for my v6?
  19. KYB GR2 Shocks/Struts
  20. "Drum Oil"
  21. MIL Elims not working properly
  22. got my tint
  23. oil pump screen
  24. Selling some stuff. Heads up for 6ers.
  25. Cheap dual exhaust setup
  26. Caster Camber Plates Needed?
  27. Long Tubes on V6
  28. V6 help
  29. Turbonetics T3/T4 Turbos?
  30. fog lights question
  31. Any ideas????
  32. Boost Gauge..
  33. M112 Adapter Plate
  34. Poll
  35. 6 cyl.performance upgrade
  36. Mod list for the new guy
  37. WOT Shift settings on sct?
  38. need some help a/c blows hot air full on freon
  39. chip question
  40. Help please
  41. struts and ball joints bad =<
  42. stock CAI (99-04)
  43. dash alarm led broke, replace or additional?
  44. 08 Mustang GT
  45. Merry Christmas, Happy Birthday, Happy Easter To MEEEEE...
  46. 7.5 bearing and seals instulatoin
  47. What size wheel spacer do you guys think???
  48. Leaking white fluid on driver's side, white flecks through defrost vent
  49. do you have 82 to 86 3.8? can you help me with vac line problem?
  50. Wheel Chop
  51. Chrome or Black Wheels on Silver Vert?
  52. how strong is the auto trans(300+ hp)
  53. New tuner
  54. Project "Under Pressure" has commenced!!!!
  55. 06 v6, best plug for power
  56. error code?
  57. A Little Advice Please...
  58. Antifreeze Leak
  59. Cold Air Intake
  60. Stock V6 not enough
  61. Can someone help me with my ac problem
  62. Some Role Playing ;)
  63. procharger and ram air kit ?
  64. mac long tube links ???
  65. Cam Sensor
  66. how to clean pistons
  67. V6 Suspension Help...
  68. For the guys with MAC Long Tubes
  69. 94 motor into a 96 problems
  70. V6 guys rejoice......
  71. Need help in getting a few parts. Need to replace hood and front bumper
  72. crackling noise ! help me out.
  73. Just Wondering...
  74. Trans Temp Gauge
  75. Serious Exhaust Help
  76. Need help witha cold air intake ASAP
  77. 03 3.8L to 01 4.6 swap
  78. Eaton M112 Roots Supercharger Vs. Procharger Cantrifugal Supercharger
  79. Eaton M112 Roots Supercharger Vs. Procharger Cantrifugal Supercharger
  80. split port swap
  81. Is it possible a stock gt takeoff can be only 2 inches in diameter?
  82. transmission Maintenance
  83. 02 sensor help needed.......
  84. Speedster Cover
  85. Custom headliner paint opinions
  86. need help w/ exhaust!!
  87. Question About Exhaust
  88. Does it void warranty?
  89. Adding Foglights
  90. BBK 65mm Throttle Body
  91. Wide-Band or Narrow-Band??
  92. Most important gauges for forced induction?
  93. How to program mileage into cluster?
  94. What do you think about this idea?
  95. Thinking of adding some gauges...
  96. Lifter ?
  97. Engine Running Hot
  98. Alum. Driveshaft Question
  99. Thickest Gear Oil
  100. Looking For Mach 1 Chin Spoiler!
  101. Ram hdx clutch finally installed
  102. 3.8 to 4.6 engine swap
  103. flaming river install tech question
  104. Just a question
  105. jacking the front up
  106. 2001 Mustang V6: Fluid/Filter fix or something more?
  107. fog lights
  108. 3.73's vs 4.10's gas mileage difference
  109. HELP-Dual Exhaust System/ California
  110. Rain rain go away
  111. how to beat my friends 2010.
  112. Should I upgrade the motor mounts??
  113. ported intake
  114. Looking for some help
  115. New member looking for help..
  116. K&N and HID KIT
  117. any auto drivers have tranny coolers?
  118. GT rear bumper
  119. 5.0 swap
  120. What color for the block?
  121. Magnaflow Dual Exhaust Help/Questions
  122. exhaust what do you guys think
  123. Need a clutch!
  124. Need Gear & t-lok inspection advice
  125. Whats a better choice
  126. Alternator problems..again
  127. Is this a good price?
  128. a few questions
  129. Grille Delete.. Make it easier to steal?
  130. Whats this in my gf's trunk lid area?
  131. turbo vs s/c
  132. is it worth 400 to go 4.3?
  133. thats right, another v8 swap thread!!!!
  134. Pro-Line vs Sport-Line Eibach springs for Vert?
  135. I know I am killing you guys with questions but here is another...
  136. Should I wait to paint car?
  137. Gettin a tuner
  138. Can turbo work with dual exhaust?
  139. 3rd time replacing heater core?!?
  140. weird noise ???
  141. Tie Rods for 96 V6
  142. HID's with fog lights
  143. intake manifold replacement?
  144. Procharger s/c on a stock v6
  145. rear end question
  146. CLUTCH CABLE. help plz
  147. My First Vortech V3 Oil Change!
  148. gauge cluster light
  149. Tuner
  150. Shelby Front Fascia
  151. Shelby Front Fascia
  152. rear vert leaks!
  153. Compressing rear springs?
  154. Replacing the motor in a 95 Mustang with 3.8L
  155. How hard to swap side scoops?
  156. Best Way to Paint Body Kit
  157. MIL Eliminators needed if purchasing a tuner?
  158. Long Tube Question
  159. Tune Needed for Gear Change?
  160. How do I tighten my clutch cable?
  161. SoCal cruise
  162. Clutch fork loose (off its bearing) HELP
  163. Changing A-arms
  164. Fogs and Spacers installed
  165. Exhaust Backfire
  166. exhaust help
  167. Clutch help
  168. Changing the brakes, Suggestions?
  169. Dual 12inch sub enclosure
  170. New Clutch?
  171. Recommended clutch
  172. duel exhaust?
  173. How do you fix gear play?
  174. Best V6 Mustang?
  175. Need the experts on this..
  176. Ford Racing COLD AIR KIT (CALIBRATION REQUIRED)??????
  177. Camshaft Synchronizer Sensor
  178. question about graphics
  179. Engine Swap ?'s
  180. roush side exhaust and mod question
  181. Elecrical issues...
  182. Problem
  183. I think I am going to go for it..
  184. awful squeal noise and a nasty smell
  185. buy a Ford Mustang Convertible 3.9 V6
  186. do gears and posi, final advice/imput??
  187. Need advice on engine work!
  188. Fog Lights
  189. obd code P0352, how realistic???
  190. Rear Sway Bar
  191. 500.000 miles
  192. Rotating Assembly...
  193. Steeda Tie Rod Ends
  194. Cam question, will it work alone?
  195. I just bought a posi/gears, what else do I need?
  196. Struts and speedo
  197. Is this a good part to get?
  198. Turbo
  199. mac h pipe => stock manifold adaptor. HELP??
  200. CAI?!
  201. little help completing my sps kit
  202. Broken Window Switch Panel on Driver Side Door
  203. Lowering springs ??
  204. Misfire...again...
  205. SVTs or FR500s?
  206. Please help!
  207. new s style rims. what tires?
  208. Quick Exhaust question..
  209. Guage cluster problems?
  210. How Do I Go About Making a Fast V6???
  211. Need Long Tubes
  212. 95 V6 O2 Sensor location
  213. Aftermarket Fog Light question
  214. do u have to break in new gears?
  215. Stangsuspension.com closed!!!!! WTF???
  216. *Update on Body kit question..
  217. K Member Kits
  218. Installed aftermarket headunit and now gague lights wont turn on?
  219. Sun Pro Tach?? Yes or No
  220. advise on roush body part
  221. Engine Misfire??? Please help!
  222. SCT X3 Tuner
  223. v6 to v8 swap
  224. head casting numbers
  225. Would the stock rotors from an 05 GT stang fit on a v6?
  226. loose steering
  227. Sluggish Acceleration
  228. Doing head gaskets have a ?
  229. 2010 V6 Mustang
  230. engine swap
  231. clutch question
  232. Problem with steering/braking...
  233. If you guys want upgraded brakes....
  234. 01-04 Console
  235. Cobra R style exhaust tips
  236. 1/4 time opinions?
  237. Fog Lights
  238. Cold Air Intake Advice
  239. Intake Spacer
  240. New ball joint squeeking.
  241. Tranny
  242. Fog Lights?
  243. New Painted Hood on
  244. Exhaust?
  245. Can someone take pictures of their 05-09 v6 mustang's bumper
  246. Performance Radiator
  247. Is it posing or not?
  248. switching out an 96 engine and transmission for an 02 engine and transmission
  249. Help
  250. CLUTCHES
