PDA
View Full Version : Motor Swap Section
Pages : 1 2 [3]
  1. 66 6 cylinder to 89 5.0 questions
  2. 95 v6 to 5.0 swap from a moutaineer
  3. Need advice on v8 swap?!?
  4. Almost there....
  5. swap from 2.3 to 5.0?
  6. Questions about swapping an engine and the difference between engines
  7. 5.0 in 95 BMW M3
  8. 2011 v6 engine into a 2010?
  9. engine/Information Conflict
  10. Mustang drivtrain swap
  11. 4.6 in 95gt
  12. I want to go 4v
  13. 98 GT swap 95 Thunderbird Crate Motor?
  14. 2005 V6 Swap to 2011+ V6
  15. very custom sbc in a sn95
  16. going from 4.0 to???
  17. S197 4.6 4V swap!?!
  18. auto to standard
  19. 3.8 to a 4.6
  20. Engine mod or swap?
  21. 98 swap from windsor to romeo
  22. motor swap for 2006 mustang
  23. Shorty Header exhaust
  24. WILL THIS ENGINE SWAP WORK
  25. Edelbrock TOP-END KIT #2091 367HP/340 LB-FT OF TORQUE I
  26. V6 Engine Swap[Question]
  27. coyote engine swap acc brackets
  28. '98 4.6 cobra motor into a '90 GT 5.0 body
  29. Ford 302 casting number help
  30. 86 4 banger to 90 5.0 conversion
  31. Can a 2011 v6 engine/tran fit into a 2007 v6
  32. Serpentine help!!!???
  33. 5.0L Coyote Swap Question
  34. 1996 mustang v6 to carb 351
  35. 88 5.0 gt motor swap to a 97 explorer gt40p engine?
  36. Block comparison Question
  37. Kooks New 1 7/8" & 2" Coyote Swap Headers
  38. Kooks Coyote Swap Headers
  39. Is it to hard for a coyote swap in a foxbody
  40. 78 cobra ii V6 to V8
  41. 351w & 4r70w
  42. 99-01 engine swap
  43. 95mustang 3.8l swap to 75 5.8l 351 w
  44. gt40p explorer heads, spark plugs to cold...
  45. Flexplate and torque converter issue
  46. 5.0 coyote swap into 2006 GT , Saleen , police clone?
  47. 5.0 HO & AOD in my '68 Coupe
  48. Weird electrical gremlins
  49. 347 stroker in 67 cougar, injector size?
  50. 2000 Mustang
  51. New mustang owner here. needing help with a build.
  52. Possible 2003 motor Swap
  53. 4.6 or 5.4???
  54. do i have a crate engine
  55. 05 V6 automatic-what will work 05-09? difference between automatic and manual trans?
  56. need 4.6 to 5.4 adaptor plates
  57. 408 CI 1995 GT
  58. 95 mustang/cougar swap
  59. Coyote 5.0 swap into 2005 V6
  60. 2001 engine in a 98 body
  61. 289 or 302 in 96 base
  62. 94 body 98 engine?
  63. 427 Windsor 460 HP
  64. bizarre tech question
  65. 97 mustang
  66. 69 with straight 6 upgrade to 5.0 ho
  67. 4.6L 66 swap advice
  68. Best streetable 9 second car?
  69. 66 with 4.6L gt swap advice
  70. engine swap upgrade
  71. SN95 Mustang Engine Swap
  72. really frustrated
  73. replacing engine 3.8
  74. 85 Stang LX 2.3 to v8 swap
  75. 4.0 swap for 5.4 4v Navigator engine
  76. 1st engine rebuild
  77. 393 build help
  78. Powerful Engine from Your Grandfathers Time
  79. Heads
  80. 94 gt with 331 cutout problem
  81. Don't laugh please: 255V8 / 4.2Liter engine wanted!
  82. Backfire on 97 Cobra after motor swap
  83. 12 coupe PCM into 08 convertible
  84. 85 mustang lx new engine help
  85. 06 mustang gt swap
  86. SBC in fox body
  87. 2003 V6 motor swap
  88. Suggestions needed on a swap.
  89. yo
  90. 1993 Coupe w/2012 Boss 302 Swap
  91. Crown Vic motor into New Edge Mustang
  92. Need some kind of help
  93. What would a Ford dealer charge to swap a 2v 4.6?
  94. Engine Crane Question
  95. 65 coupe MPG swap
  96. 85* Stang Engine Question
  97. v6 motor swap
  98. V6 to V8 swap
  99. question about the 4.6 3v and 4.6 2v
  100. 1995 mark VIII 4.6 and 4R70W into 1984 CJ-7
  101. 5.4 hps intake needed
  102. Need Suggestions & swap info 89 GT wrecked 60k miles
  103. 2000 3.8l Motor Replace
  104. F150 coyote into an 85 notch
  105. mark viii swap questions
  106. need transmission help
  107. M112 Eaton Swap to '99-'04 3.8 Mustang?
  108. Looking for a Engine
  109. S197 3V V8 swap
  110. balancer/flexplate and pulley questions
  111. i need a little help
  112. 2000 gt swap
  113. 5.4 pulleys to 4.6 help
  114. Need help Guys on my Eleanor
  115. 02 gt swapped into 03 v6
  116. 95 to 00 3.8
  117. help with 351w info
  118. 1996 3.8L swap to a 97 3.8L
  119. 408 stroker k member issues
  120. 03 460 swap
  121. 4r70w with 351w
  122. 2013 5.0 into 91 lx
  123. 91 lx 4 cylinder to 351
  124. Engine swap into Cougar 2000
  125. 1983 mustang v6 to v8 swap. kit?
  126. 93 cobra motor in an 89 gt
  127. new to 3V swap
  128. 5.4 swap help!! stock motors about to go!!!
  129. 289 with Duraspark and other stuff
  130. V6 to V8? or turbo..
  131. 5.0 from 87 fox to 98 gt that was a 4.6
  132. swaping a 03 4.6 dohc into my 98 gt
  133. 02 v6 swap to v8
  134. Reverse Lights
  135. Seeking information about turbo for 2.3l
  136. 1989 Grand Marquis to 1983 Fox Body Swap
  137. 67 swap
  138. 89 to 93 engine swap
  139. 281 to 351 swap in a new edge?
  140. The age old question, build the 4.0 or swap in V8 (GT & sixers welcome!)
  141. swapped 3v engine
  142. 96 4.6 into a 97 gt please help
  143. 351w swap into an 04 v6 mustang
  144. 1995 Ford Mustang Base Model
  145. Ls1 swap in 99 v6 mustang
  146. '96 Cobra 4.6 into '00 GT
  147. Swap 4.0 for 3.7
  148. 351 winsor
  149. tritan 6.8L 3 valve swap questions
  150. 5.0 in a 99 mustang
  151. 95 mustang v6 swap to 98 v6
  152. F-150 Block
  153. NEED HELP PLEASE READ
  154. SN95 coyote swap
  155. LS heads on a windsor
  156. WIRING QUESTIONS
  157. 98 Explorer 5.0 into '68 Mustang
  158. 20002 5.4 Harley Supercharged Engine in a 2005 Mustang
  159. engine mounts to drop a 351 Windsor into a 67 coupe
  160. 5.8 swap with t-56
  161. 4.6 swap/ build
  162. Turning 2000 Mustang into Project
  163. 1986 2.3l to 5.0
  164. Quick transmission question!!
  165. 96 GT 5.4 Swap Idle Issue?
  166. 96 v6 auto to replace 01 vg manual
  167. Transmission Shifter Problems
  168. 1997 ford mustang v6 to v8 swap.
  169. 96 gt 4.6 and trans swap for 96 cobra
  170. 4.0 to 4.6 or 5.4??
  171. 4.6 to 5.4 swap 3v
  172. 84 v6 to v8, wiring harnesses question.
  173. Ive tried and tried
  174. please help!!! 2002 v6 into 1996 v6
  175. T5 Conversion
  176. 01 GT to Bullitt
  177. What should I swap to?
  178. 408 stroker swap, help needed
  179. 4.6 2v running rich!
  180. Swap 99 4.6 to a 03 supercharge 4.6L
  181. 1996 to 2000 3.8 engine swap
  182. 99 gt swap to a 96 4.6
  183. 1998 v6 to 5.0 swap
  184. engine swap v6 to v8 base model 95 not a fox body
  185. 3.8 to 5.0 need help with wiring
  186. 91 crown vic 5.0 into a 95 mustang V-6?
  187. What yer mustang would be compatible with my 2004 ford mustang v6?Need an ECU
  188. Carb to EFI engine swap
  189. V6 to v8 swap
  190. My first engine beyond a 4cylinder
  191. 1984 Fox with 3.8 to 5.0 HO Swap
  192. help with my incomplete 289
  193. New kid on the block
  194. swap?
  195. 1999-2004 460 swap
  196. swap questions that have probably already been answered elsewhere
  197. 5.0 pushrod or 4.6 3v
  198. 93 V6 swap for 5.0 V8
  199. I Need Help Identifying These 4v Heads.
  200. 408 stroker questions
  201. Engine swap v6- coyote crate, questions.
  202. 4.0 to 5.4 Swap
  203. Engine swap
  204. '85 SVO swap electrical problems.
  205. 5.4 SOHC VS DOHC
  206. drive shaft gt manual vs auto
  207. Ecu question
  208. Engine swaps, what are the costs?
  209. sbf s10 conversion
  210. My 4.0 to 4.6 Swap
  211. So It Begins - 5.0 Coyote in 99-04 Car
  212. wrecked sc lookin for new life
  213. 302 for a 351
  214. Build Threads
  215. >>> New Section <<<
  216. 2011 5.0 in a 1992 mustang?
  217. 07 4.0 - pushrod 5.0 swap
  218. 4.0L V6 to 4.6L V8 Engine swap
  219. 2005 Mustang V-6 to V-8 conversion
  220. Swap 4.0 to 5.4?
  221. 4.0 to 3.7 swap...(?)
  222. Step by Step guide to installing a Mark VIII motor in a 96+ GT.
  223. PowerHouse 4.0 to 5.4 3V Turbo project - Phase 1 Complete
